Intermittent Rev Counter Problem
RichieK
Post by RichieK » Wed Jul 24, 2013 3:00 pm
I recently started experiencing a problem with the rev counter in my S1:
Occasionally if I hit a bump the rev counter dies - it can be brought back by tapping on top of the Stack
Assuming it was a loose connector I removed the Stack and reseated the connector - but still no joy :(
I'm pretty sure the problem is the connector, if I wiggle the connector it makes the rev counter drop out.
Any suggestions how I can fix it?
Azure Blue S1 Elise
Graphic & Logo Design, Edinburgh & Glasgow - https://keeble.uk.com
Re: Intermittent Rev Counter Problem
Post by Shug » Wed Jul 24, 2013 5:12 pm
Give you good odds it's actually the cable on the sensor in the rear wheelarch. They fracture all the time. Must have fixed mine 4-5 times in the 10 years I had my S1...
Post by BiggestNizzy » Wed Jul 24, 2013 8:35 pm
Post by robin » Wed Jul 24, 2013 9:49 pm
If banging the stack fixes it then my money is on the needle being loose on the spindle. Nightmare fix! Ask MMC would be my advice :-)
RichieK
Post by RichieK » Wed Jul 24, 2013 11:24 pm
Thanks
I'll check the sensor wiring first.
Where about in the wheel arch / which side is it on?
Azure Blue S1 Elise
RichieK
Post by RichieK » Wed Jul 24, 2013 11:50 pm
...just had a quick google for images.
Is the sensor for the speedo? - does the rev counter not get its feed from the ECU?
The speedo work fine - it's just the rev counter that has a problem.
Azure Blue S1 Elise
Post by Shug » Thu Jul 25, 2013 8:40 am
Sorry skim read - ignore me, yeah sensor is for speedo. :oops: :kermit
RichieK
Post by RichieK » Thu Jul 25, 2013 9:25 am
No worries - thanks anyway Shug :)
Azure Blue S1 Elise
RichieK
Post by RichieK » Thu Jul 25, 2013 10:00 am
robin wrote:If banging the stack fixes it then my money is on the needle being loose on the spindle. Nightmare fix! Ask MMC would be my advice :-)
I think the needle is pretty solid - it seems ok when it does its re-set every start up, and it seems to read fine when it's working.
I'm at CLCM this afternoon for a geo setup so I might nip into MMC while i'm there. Whatever the problem is, it's probably past my DIY abilities anyway :lol:
Azure Blue S1 Elise
RichieK
Post by RichieK » Thu Jul 25, 2013 6:06 pm
Got it booked into MMC - I'll update the thread with their diagnosis
Azure Blue S1 Elise
