petrol cap broke!
Dipper
petrol cap broke!
Post by Dipper » Mon May 13, 2013 6:20 pm
went to fuel up the barrel came oot wi the key along with broken bits of plastic! the barrel looks like its missing some bits as well. fortunately i picked a petrol station with a garage attached and the got the cap off with a screwdriver!
im guessing ill need a new cap with a barrel and therefore a new key?
Stu160
Re: petrol cap broke!
Post by Stu160 » Mon May 13, 2013 8:00 pm
I think thats happened before?
Stu
S1 S160
Caterham 310R
Stewart
Post by Stewart » Mon May 13, 2013 8:38 pm
We discovered on one of the frolics that the 3 exige convoy we were in any of the ignition keys fitted the fuel filler caps so you will hopefully not need to bother with a different key for the fuel cap only. I've not explained that very well but hopefully you catch my drift :oops:
Stewart
Dipper
Post by Dipper » Mon May 13, 2013 9:11 pm
might explain why the barrel is missing a load of the tumbler bits. might be generic!
Post by j2 lot » Mon May 13, 2013 10:25 pm
I seem to recall being told there are only about 7 different options for the petrol cap keys so there is a 1 in 7 chance that your ignition key will work in the new cap lock - predictably mine didn't when it was replaced. :roll:
Mikem7709
Post by Mikem7709 » Tue May 14, 2013 11:39 am
Will definately be trying my ignition key in the petrol cap, I'm sick of jabbing myself in the leg with it hanging down from the ignition
Jacobite
Post by Jacobite » Tue May 14, 2013 10:49 pm
IF the s2 fuel filler cap is a threaded type like an S1 version? sorry I don't know the differance
then you can get a genuine VW Locking fuel cap off e-bay for a few £ and cut off the raised reinforced coller off the bottom of the outer part of the cap~ this would foul with the bodywork on an S1 you then end up with a cap which locks / unlocks with a single 180 degree turn of the key which still locks tight enough to give you the gas hiss when you unlock it
Post by j2 lot » Wed May 15, 2013 9:58 am
S1 & S2 caps arent the same
