Accumate
jimbo
Accumate
Post by jimbo » Sun Feb 03, 2013 9:41 pm
How long can I keep an Accumate plugged in and attached to the battery terminals for? Is there an upper limit?
James
Sent from my TITAN X310e using Board Express
S1 Elise 111s
Re: Accumate
Post by renmure » Sun Feb 03, 2013 11:06 pm
I confess to having had my Caterham battery connected for about 9 months :oops:
No issues
Re: Accumate
Post by Mikie711 » Sun Feb 03, 2013 11:13 pm
Had mine on the Evora for 3-4months now and all OK as far as I can tell. It's a conditioner so only feeds a maintenance charge not on full charge. My alarm doesn't even notice it and the alarm is the reason I use it.
jimbo
RE: Accumate
Post by jimbo » Mon Feb 04, 2013 12:14 am
Ok cool, thanks guys :)
Just bought one cause I couldn't bear the thought of having to swop out another battery
S1 Elise 111s
Re: Accumate
Post by Dominic » Mon Feb 04, 2013 10:34 am
Mikie711 wrote:Had mine on the Evora for 3-4months now and all OK as far as I can tell. It's a conditioner so only feeds a maintenance charge not on full charge. My alarm doesn't even notice it and the alarm is the reason I use it.
Mine is on all the time when the car is in the garage (which is quite a lot in this weather). No probs. As others say, it stops charging when the battery is full.
flyingscot68
Re: Accumate
Post by flyingscot68 » Mon Feb 04, 2013 1:38 pm
I use a similiar type charger on my bikes called an Optimate.
You can leave them on the battery for years nevermind months :thumbsup
Re: Accumate
Post by Ferg » Mon Feb 04, 2013 9:13 pm
I take mine off for a week now and again. A friends garage burnt down using a trickle charger so a little paranoia is aloud. lol
Re: Accumate
Post by j2 lot » Mon Feb 04, 2013 10:25 pm
Ferg wrote:a little paranoia is aloud. lol
allowed :blackeye
:wink:
Re: Accumate
Post by Dominic » Tue Feb 05, 2013 10:53 am
Ferg wrote:I take mine off for a week now and again. A friends garage burnt down using a trickle charger so a little paranoia is aloud. lol
These are not trickle charges. Trickle chargers (AFAIK) slowly gently charge, but keep doing so when the battery is full. The Acumate stops charging when the battery is full. :thumbsup ...(now hopes my garage (& house) don't burn down)
Re: Accumate
Post by robin » Tue Feb 05, 2013 11:16 am
All chargers have voltage and current limits, even ones where that wasn't an explicit design goal. The problem comes when the design fails to enforce a reasonable voltage limit and so tries to pump current into your battery when it is full. To be honest, it is so trivial to make a safe lead acid battery charger that will keep it at somewhere around 50% charge (which is more than enough to restart the car) that I am amazed at the problems these chargers create ... but they do (perhaps because they try to keep the battery at 100% charge ... why?!?).
