lost key
c murray
lost key
Post by c murray » Fri Jun 22, 2012 8:39 pm
lost the only key for the 340r what next :?:
lost lost lost we gav
Re: lost key
Post by robin » Fri Jun 22, 2012 10:23 pm
Luckily the 340R has exactly one lock so you can easily buy a new lock and barrel (perhaps off some other elise from a scrap yard) and be done with it.
In the meanwhile you can remove the old barrel and use a screw driver to turn the ignition on/off.
Re: lost key
Post by meatball » Fri Jun 22, 2012 10:23 pm
Where did you see them last?
Gourlay83
Re: lost key
Post by Gourlay83 » Fri Jun 22, 2012 10:25 pm
Lose the car
Re: lost key
Post by tut » Fri Jun 22, 2012 10:30 pm
meatball wrote:Where did you see them last?
If he knew that then he would know where to find them.........
CubanGav
Re: lost key
Post by CubanGav » Fri Jun 22, 2012 10:38 pm
Can he contact lotus for a new set of keys?
He needs to disable the steering lock to put it for a geo. Apparently a wee screwdriver starts the car no bother.
I've sent him what he needs to do but opening an attachment on an email might as well be rocket science. Like my Dad - if you can hammer it, cut it, glue it or mow it then it's fine. Pushing buttons in a specific order on a keyboard is like asking him to juggle with his feet.
Gourlay83
Re: lost key
Post by Gourlay83 » Fri Jun 22, 2012 11:03 pm
You can remove the barrel, there is a little pin you push (quite hard to see) and the barrel slips out but .... to do this i'm pretty sure you need to have the key in and the steering lock off.
Next option would be to hammer off the bolts (they have heads that shear off to stop dodgers simply un bolting the lock assembly and steeling your car). This would be difficult to do in place so might be easier to remove the column and do on a bench.
Complete pain in the arse,
Alan - BEST OF LUCK
P.S You can buy a complete lock set from Lotus, but comes as a barrel and two door locks.
P.P.S The car has no immobiliser, so you can remove the ignition switch (other end of barrel) and use a screw driver to start the car.
Gourlay83
Re: lost key
Post by Gourlay83 » Fri Jun 22, 2012 11:08 pm
robin wrote:Luckily the 340R has exactly one lock so you can easily buy a new lock and barrel (perhaps off some other elise from a scrap yard) and be done with it.
Just read this, covers everything he needs to do.
Sorry Robin
c murray
Re: lost key
Post by c murray » Fri Jun 22, 2012 11:37 pm
just need to get the fxxn car going re bookin for geo on thursday at wallace they could not do geo because did not take off my mud gaurds i give up
c murray
Re: lost key
Post by c murray » Fri Jun 22, 2012 11:41 pm
p.s the ex has the master keys
Re: lost key
Post by meatball » Fri Jun 22, 2012 11:53 pm
A wee joke....?
andyc
Re: lost key
Post by andyc » Sat Jun 23, 2012 6:53 am
Do you want to ask the ex if she will give me the spare key? You could try looking harder for the keys...if you are like me....they will be right in front of you!!!
Blue S2 (sold to the plumber)
Seat Leon Cupra Commuter Car
c murray
Re: lost key
Post by c murray » Sat Jun 23, 2012 6:50 pm
One big drill one big hammer job done back on the road
duggiesmith
Re: lost key
Post by duggiesmith » Sat Jun 23, 2012 9:39 pm
My kind of car maintenance.
Duggie
Aubergine Elise S
Plum Crazy Exige 410 Sport
Re: lost key
Post by meatball » Sun Jun 24, 2012 12:03 pm
I bet you find the key now!
