De Cat
De Cat
Post by Stephen » Thu Sep 01, 2005 8:18 pm
Fitted a decat pipe the other weekend and ever since the car has been a bit smelly with exhaust fumes. Is this normal?
ninja
Post by ninja » Thu Sep 01, 2005 11:02 pm
you've either not sealed the joints properly! which lets face it is unlikely
or
it's the film coating on the new exhaust burning off under the heat?
if the exhaust is blowing then the problem is the first one! if it's not blowing then most likely just the coating burning off! takes a week or so for this to go away from experience (not with a lotus tho - mini, rover 820si, civic etc)
ninja
Post by jj » Thu Sep 01, 2005 11:49 pm
I noticed mine is sometimes fumey, and I have read that is normal practice after a decat so I have never worried.
Post by Shug » Fri Sep 02, 2005 10:20 am
You should smell the stench of mine!
Aye, they run a bit rich anyway, taking out the cat means you smell it more. :)
CSK423
Post by CSK423 » Sun Sep 18, 2005 12:27 am
Yip mine's pussy less and it's rank rotten, when you think about it the CAT would have prevented these fumes escaping previously, not to worry mate enjoy the extra noise
Bell and Colvill Super 140 S1 Elise
gordon
Post by gordon » Sun Sep 18, 2005 1:22 am
Especially when you reverse. Fills the car with fumes as you drive back thru the reek
