Brake woes
- Lazydonkey
Brake woes
For the past few days the brake pedal on the vx seems to be "lazy" and after my hour long commute it gets so bad that i have to hook my foot under the pedal to get the brakes off.
Pads and discs were new under a thousand miles ago and none of the discs are hot to touch after a run...... Although it does seem to get worse as the car heats up. Front calipers were refurbished at the same time as the discs and pads went on.
Don't think it's a sticking caliper as my guess is that the hooking trick wouldn't work if it was.
Any ideas? Also is this something I should consider p&l for?
Thanks in advance
Donkey
Sent from my Desire HD using Tapatalk
Thanks in advance
Donkey
Re: Brake woes
Could be an issue at the master cylinder rather than at the business end. Simplest thing to check first is that the spring on the pedal is still connected properly.
Re: Brake woes
How is the pedal's own pivot bush designed? Elise clutch "trunions" get very stiff although maybe not sufficiently so to prevent full return action (they do hold the pedal down a little though, IIRC).
Re: Brake woes
P&L no go Martin unless it is a mechanical fault as opposed to wear.
Re: Brake woes
Campbell, the brake pedal trunion works exactly the same as the clutch one but doesn't wear in the same way as the pedal doesn't move as far.
Most like a master cylinder problem but you'll probably struggle to get it on P&L unless you can show the AA man you've got no brakes so can't continue.
Dan
Dan
- Lazydonkey
Re: Brake woes
Thanks guys - found some guys on the vx site with the same issue so going to try changing fluid and the return spring before i go spending serious money on anything
- mwmackenzie
Re: Brake woes
Ali had one last year, same issue, can't for the life of me remember the cause, maybe worth a call?
Re: Brake woes
Let me know if you need a spanners sesh! I some jobs to do on the Liz too.Lazydonkey wrote:Thanks guys - found some guys on the vx site with the same issue so going to try changing fluid and the return spring before i go spending serious money on anything
Re: Brake woes
Ta for the insight, Dan.roadboy wrote:Campbell, the brake pedal trunion works exactly the same as the clutch one but doesn't wear in the same way as the pedal doesn't move as far.
