Im told it does have one.
Honda O2 Sensors
Honda O2 Sensors
Can someone tell me where the primary O2 sensor is located on an Honda elise ? All the Honda sites say its on the top of the exhaust manifold but starting to think Im blind.
"I've had enough sh1t"
Re: Honda O2 Sensors
Hi Mikey,
It's in the manifold just before the rear flange where it bolts to the cat/cat pipe.
It should be screwed into the top part of the pipe with the wires heading up over.
This is all assuming you have a Stark manifold.
HTH
Dan
HTH
Dan
Cheers . Did change the cat so might have damaged it or moved the wires . Ill get underneath the car tom and have a look.
