by Rich H » Sun Aug 20, 2006 11:01 am
Morning all, my 4-2-1 arrives tomorrow with a bit of luck. While I will attempt to remove the original Lambda sensor I recognise that this is probably a waste of time.
The liz parts ones are over £70 but will this fit? it's £18
http://tinyurl.com/p27hx
Ta
roadboy
by roadboy » Sun Aug 20, 2006 4:39 pm
Don't normally have any trouble getting old ones out Richard. If its being stubborn, cut the wires and use a ring key.
Dan@JPS
by Rich H » Sun Aug 20, 2006 4:41 pm
Cheers Dan, I'll have a crack tomorrow and if necessary get medieval on it....
- Jedi Master
by robin » Sun Aug 20, 2006 6:13 pm
Sounds like the same part - if you do fit it be sure to mate the wires well - the heater wires carry a fair old current and obviously it all gets pretty hot anyway given where it's fitted.
by Victor Meldrew » Sun Aug 20, 2006 8:33 pm
RICHARDHUMBLE wrote:Cheers Dan, I'll have a crack tomorrow and if necessary get medieval on it....
electric drive impact available if required.... just give me an excuse for a run if its dry..
by Rich H » Sun Aug 20, 2006 9:05 pm
Cheers John, May have to resort to special measures...
If its raining (Or the boss won't let you out!) I'll use the air driven one at work I found the other day.
by Rich H » Tue Aug 22, 2006 5:04 pm
Not as yet I'm about to wrap the 4-2-1 then fit may be tomorrow...
