air filter cleaning. will this work????
Post by mckeann » Tue Aug 15, 2006 2:02 pm
Hi folks, i have a K and N filter on my car now, and have noticed the induction noise has changed pitch recently, i believe because its choking up. I want to give it a clean before i go down south again, but i cant get hold of a K&N filter cleaning kit.
I have an ITG cleaning kit, will this be ok. I imagine all the companies want you to buy there own stuff, but surely dirt cleaner and oil is all pretty much the same??
Post by Rich H » Tue Aug 15, 2006 2:07 pm
I use a K&N cleaner on my hurricane. It's just a solvent to remove the oil and then filter oil afterwards. As long as they are both for cotton filters it should be ok.
Give it a blast with the solvent, then put it in a bucket of warm soapy water to shift the clag. I use a toothbrush to help but be careful of the gauze.
Once it's clean rinse it with loads of clean water (From the inside out) and let it dry naturally. Re-oil it once it's dry and the jobs a carrot :wink:
Oh and halfrauds sell K&N cleaning kits in the "Nedspeed" section :thumbsup
Post by mckeann » Tue Aug 15, 2006 2:08 pm
the ITG is a foam filter i think
but i still dont think it'll make any difference ??
Post by Rich H » Tue Aug 15, 2006 2:13 pm
Probably not, the foam things would be more delicate than the cotton efforts. Have a go and you can be the guinea pig... :lol:
Post by mckeann » Tue Aug 15, 2006 2:15 pm
halfords have it in store, so just gonna go for that. I couldnt see it on there website, so thats why i was gonna risk it
thanks for the goading tho :wink:
Post by Rich H » Tue Aug 15, 2006 2:17 pm
That bloke (Bird?) needs a longer stick....that's a brown bear...
Post by mckeann » Tue Aug 15, 2006 2:26 pm
RICHARDHUMBLE wrote:That bloke (Bird?) needs a longer stick....that's a brown bear...
oi, stop poking, it tickles
Post by Shug » Tue Aug 15, 2006 2:35 pm
That's Mr Facking Ben.... This one is you ;) :lol:
Post by mckeann » Tue Aug 15, 2006 2:49 pm
aye, thats more like it. firey temper and all that
Post by Shug » Tue Aug 15, 2006 3:18 pm
mckeann wrote:aye, thats more like it. firey temper and all that
Nah, just a weapons-grade ginner...... :lol:
Post by alicrozier » Tue Aug 15, 2006 3:33 pm
You're probably down to 160bhp like tut... ;)
Remember you're sooking much more air than the rest of us (maybe Jamie excluded) :) so you need to clean the filter more often.
I used to clean the hurricane every 1K miles (just dry clean and re-oil, proper clean every 3-4 K). No excuse 'cos it was so easy in the K, guess it's a little bit trickier to get at in the Hunda.
Post by mckeann » Tue Aug 15, 2006 3:39 pm
you have to drop the wheel arch liner out to do it. no big deal really. It definately makes a difference, i can hear the induction note has changed.
Post by Shug » Tue Aug 15, 2006 3:43 pm
mckeann wrote:you have to drop the wheel arch liner out to do it. no big deal really. It definately makes a difference, i can hear the induction note has changed.
Yeah, you have to do the same with mine. Pain in the arse, but really worth it. Take it you went K&N to avoid any worries about the foam filter breaking up? I think my pipercross will be getting replaced with a big bore K&N at some stage....
Post by mckeann » Tue Aug 15, 2006 3:45 pm
thats just what sinclaires put on it. The ITG wouldnt fit, and they got more power from K&N over the hurricane, so i went with that. does seriosuly strangle power when dirty tho
