connectors
connectors
Post by BiggestNizzy » Sat Jul 23, 2011 9:33 pm
Does anyone know were you can get replacement connectors for an s1 elise I am looking for a 2 wire waterproof connection too fit onto the end of the wheel speed sensor. I have repaired it twice now and want to fix it properly.
Re: connectors
Post by Rich H » Sat Jul 23, 2011 9:40 pm
pole-volt.co.uk do loads of connectors, I don't know what you are after specifically though...
Re: connectors
Post by tut » Sat Jul 23, 2011 9:56 pm
Tis the two pin connector from the Stac that plugs into speed sensor on the nearside rear wheel hub.
Re: connectors
Post by Rich H » Sat Jul 23, 2011 9:59 pm
I meant I have o idea what flavour of connector it is! They are usually econoseal or superseal style but I'm not sure...
Re: connectors
Post by Mikie711 » Sun Jul 24, 2011 12:45 am
Rich H wrote:I meant I have o idea what flavour of connector it is! They are usually econoseal or superseal style but I'm not sure...
Of the 2 types econoseal is more common on the Elise as it is smaller. I used polevolt when building my S1 you may be able to send them a picture and they will tell you weather or not they can get that particular plug.
TBA
Re: connectors
Post by BiggestNizzy » Sun Jul 24, 2011 11:46 am
It looks more like a superseal connector but it's not quite right.
Re: connectors
Post by Rich H » Sun Jul 24, 2011 11:52 am
Might be a copy of one of them so it looks slightly different?
Post a piccy!
Re: connectors
Post by BiggestNizzy » Sun Jul 24, 2011 12:18 pm
Will try and get time to pop the wheel off and take a pic.
It's def not a superseral, I got a better picture it has a shape on the end to time it. instead of the red bit. other than that it's identical.
Re: connectors
Post by Mikie711 » Sun Jul 24, 2011 12:48 pm
Wonder if it's a delphi connector like this.
TBA
hiscot
Re: connectors
Post by hiscot » Sun Jul 24, 2011 1:22 pm
It does look like the one mike posted if its the same size ? elise one has ped 16 on the clasp
When mine went the cable was rotten so I spliced a long piece in however it also broke direct at the pins , I could not find a replacement but pressed the rotten pins from the elise plug out and used brand new pins from an amp c4 connector new wires soldered, heat shrink covered, dab of servisol , press the new pins in . job done
bob
Re: connectors
Post by BiggestNizzy » Sun Jul 24, 2011 1:53 pm
That looks exactly like it :thumbsup
cant find anyone selling one though
Re: connectors
Post by Mikie711 » Sun Jul 24, 2011 2:18 pm
get it here
TBA
