Leaky shocker
- point n squirt
Leaky shocker
I have a leeky rear shocker so needs fixed asap. Think i will take the cheap option and stick with the blisteins [although those street nitros look nice] so where is the best place to get them as alot of the usual sites dont even list them for a 04 111r.
- point n squirt
Re: Leaky shocker
I saw that but was too late. You snooze you loose
SteveCowen
Re: Leaky shocker
I have some old ones if you want? I replaced mine with the Nitron Street series last year. Three of the four were OK when removed - have done around 45k miles. Assuming that your newer car uses the same spec as my 2001 Rover S2?
You can collect them any time you're passing?
Steve
Steve
- point n squirt
Re: Leaky shocker
Thanks for the offer Steve im just about to replace the rears with the same again , only done 18,000 was expecting a bit more life out of them but i suspect it was due to hitting a cattle grid at speed on a SE run last year.Came close to selling the Elise then the sun came out
Good to see your still a lurker on here.
