Rivnut Gun
Rivnut Gun
Was hoping to fit my Elise-Shop Toe Link upgrade this weekend then I releaised that I need a Rivnut gunfor the rivnuts to fit the shear plates. Tried to get one this morning in town, but no joy. Just wondered if anyone in the Aberdeen area had one that I could borrow for a couple of days.
Re: Rivnut Gun
Use a nut and bolt?
Just wind the nut onto the bolt, screw the bolt into the rivnut.
Install the rivnut and hold the bolt head while 'undoing' the nut.
It will form the rivnut no problem.
Re: Rivnut Gun
When I fitted my set I'm pretty sure they came with a set of small nuts & bolts rather than rivnuts (there was also the option to rivet the plate on, but I wasn't keen on that).
Re: Rivnut Gun
Thanks Gents,
I'll give the nut and bolt method a go tomorrow, I was just worried it wouldn't compress properly and I'd be left with it spinning and it would be a bitch to drill it back out.
Re: Rivnut Gun
Kinger, just read this.
I have one you can borrow, i'll be in the paintshop in Ellon all day. You can pick it from there.
Alan
Alan
Re: Rivnut Gun
Hi Alan,
Thanks, if its OK I'll pick it up around 1pm. Where is the paintshop in Ellon ?
Re: Rivnut Gun
Just down from our old prison
Think Alan uses/used Castle Park Autobody?
Re: Rivnut Gun
Castle park autobody, 2nd right after the turning for Tesco then follow the signs.Kinger wrote:Hi Alan,
Alan - 07766666080
- thinfourth
Re: Rivnut Gun
I've got one too.
Work in portlthen if thats any easier
