Battery...
- skellyjohn
Battery...
I remember hearing that replacing the battery is a bit of a nightmare (s1).
Can anyone recommend anybody in Glasgow that can do the job?
s1 111s (kind of)
Re: Battery...
It isn't really that bad - why not give it a go first!skellyjohn wrote:I remember hearing that replacing the battery is a bit of a nightmare (s1).
You must have too much money
Will a garage will do a better job than yourself? The YTS lad will lean over into the front access and pull out the battery, you will then be £30 lighter
Go on have a go yourself!
- skellyjohn
I think I'm going to prefix my name with 'HOPELESS'.
Radiator cowling could be of a spaceship for all I know! I can put petrol in the car, screen wash and that's about it. I've even managed to overfill my oil so I can't really say that I can do that.
But if I was to give it a go myself.... What kind of battery should I buy?
Thanks for the replies.
s1 111s (kind of)
Ah the Ed school of mechanics....skellyjohn wrote:I think I'm going to prefix my name with 'HOPELESS'.
Easy job, not too taxing just fiddly. IIRC the halfrauds battery chart is wrong, and it won't fit... Dunno on the best sort.
- skellyjohn
I found this in SELOC...
just did this (change the battery) for the first time on my S1 this morning...
the job is not as difficult as it first seems. And yes, once a battery has been discharged (gone flat) it can sometimes never recover properly.
You need a type 063 battery (Halfords - £39.95) and this is what you do...
1. Open front cover and hold/prop it open;
2. Pull the windscreen washer bottle from it bracket and place to one side (be careful if using the radiator as a tray);
3. Unscrew the three 10mm bolts holding the battery clamp/washer bottle mount in place and pull the clamp out;
4. using a 13mm spanner undo and disconnect the battery leads (neg first) - the alarm will go off at this point;
5. Disconect the battery overflow pipe from the current battery;
6. Pull the battery up and out of the car - this is the hardest part as all the wires and radiator + bits and pieces are in the way, it requires a lot of jiggling and juggling but it will come out.
Then in typical Haynes fashion do everything in reverse order to get the new battery in. If you are replacing an original battery with a new (Halfords) type one, which is slightly smaller, then the battery clamp will not fit it properly and a bit of inventive engineering is needed to clamp in securely in place - but if you want it done right then you can get a different battery clamp from your Lotus dealer for about £8.
In all, it took me 10 minutes and only a bit of swearing..
MIGHT give it a go - or wait until it's at the garage this week to get the oil changed after my over fill balls up.
For those that are interested, I bought the car in 2004 for £11.8k and have spent more than that now on repairs. My mechanic has a lovely house in the South of France!
s1 111s (kind of)
If its in the garage anyway then let them do it. But DIY is the way forward!
If you do it yourself get a box of plasters on standby and be careful with the battery leads on diconnect/reconect and keep them away from the chassis!
- The_Rossatron
2nd that. Same for S1 and S2 and all rover 218s too apparently.Baggy wrote:Bosche silver top 4P available from costco for £25.25. Comes with a handle too.
http://www.allflashnocash.com
