Side lights not going off
Post by kenny » Sat Mar 05, 2011 2:59 pm
Following winter hibernation my side lights seem to have developed a mind of there own. Once switched on they randomly switch on and off before eventually staying on. They wont switch off again unless I disconnect the battery.
Any thoughts?
Re: Side lights not going off
Post by mckeann » Sat Mar 05, 2011 3:03 pm
its buggered :thumbsup
Post by tut » Sat Mar 05, 2011 6:17 pm
Same here, but mine is the button sticking in and I can not be bothered changing it again, so just use dipped headlights.
neil
Post by neil » Sat Mar 05, 2011 8:15 pm
I'd have thought its the switch. Presumably the 3 light switches are the same so you could swap it for the fog or headlight one and see what happens
Exige V6
Post by alicrozier » Sun Mar 06, 2011 6:34 pm
Quite often the switch pack Kenny...
Post by robin » Mon Mar 07, 2011 9:37 am
Yes, I think the switch module is more likely than the switch itself. Does the same thing control the A/C and so on too?
