Took it up to 'the garage' in motherwell to get it's MoT done. Failed on the following:
offside front wheel bearing rough when rotated
both rear brake discs ' in such a condition that it is seriously weakened'
service brake efficiency below requirements ( 41%)
parking brake efficiency below requirements ( 15%)
I knew the handbrake was sh*t, the rear discs are rusted but it lives outside and I've done 30 miles in the last 3 months, is it worth trying to clean up the discs? The guy thought the rear calipers might be causing problems as well, may need replaced if they wont free off.
I'm gutted to be honest, road tax and insurance also renewed this month and I've barely driven it so it just seems like a money pit.
Posting for advice on best value ( not cheapest) solution.
Mintex 1144 pads or OEM?
Plain brake discs or Ultimax turbo discs? It currently has drilled and grooved discs which previous owner put on it, I'm unlikely to do more than 2 track days a year so I'm more into something that won't cost a fortune and will give me good stopping from cold.
Front wheel bearing - will AA Parts and labour cover that?
Also had an advisory - coolant leak. I think that's because I haven't tightened temp sensors well enough when I did them few weeks ago. I hope.
It's also now got a misfire - think this is just dampness getting as it was like that once before and a hairdryer sorted it.
