Suspension related....
Post by Rag_It » Sun Sep 26, 2010 8:46 pm
Having picked the car up over a month ago now, on the drive back up I knew something wasn't quite right, there was a slight clunking noise, usually at slower speeds on bumpy roads. I let Tommy know, and he said he wasn't aware of anything but would see me right if anything was an issue. I had been meaning to take it over to Robin, but not having driven it a lot due to work, and finding time to take it to Robin for further investigation i'd plan to visit next week.
This evening at very slow speed a very loud clunk from the left rear and then what sounded like a metal bar banging about on the undertray.The left rear tyre is indeed slightly closer to the clam now, with about one hand fitting inbetween from the tyre to the clam, about two or three on the other side. I know Tommy had the LSS refurbed only a year ago, and therefore thinking it might be wishbone or something?!!! <those that know me I am not technical however!>
Good right hand side rear wheel
Left hand rear wheel
It'd be nice and simple if i had got round to adding it to my AA cover and P&L, however having been too busy I haven't so it looks like i might have to nurse it to Falkland Performance!
Any thoughts?!!
Dave
Re: Suspension related....
Post by woody » Sun Sep 26, 2010 9:04 pm
could be a corroded lower spring platform letting go. not expensive and easy fix if no other damage.
take the wheel off, have a look and get some more pics.
Post by robin » Sun Sep 26, 2010 9:22 pm
Or a damper mounting bolt snapped ...
Don't drive the car.
Do take the wheel off and try and get some pictures from various angles inside the wheel arch.
Post by Rag_It » Sun Sep 26, 2010 9:26 pm
You want me to take the wheel off............. :P Where is the clunking coming from, as it sounds like something is flaling about?
I will try and do this some night during the week, although no idea where the jack and everything else is!
Thanks for the advice guys :thumbsup
Dave
Post by mwmackenzie » Sun Sep 26, 2010 10:02 pm
I'm with woody on this as mine are well corroded and needing replaced.. A job for another year as car in storage now
Post by robin » Mon Sep 27, 2010 8:12 am
There is no jack - you need to borrow a trolley jack from somebody else; you may need to drive the car up onto a plank or paving stone to gain a little extra ground clearance under the jacking point (see your owner's manual for jacking instructions).
If you're stuck I can pop up and take a look, but won't be before Wednesday.
shooomer
Post by shooomer » Mon Sep 27, 2010 8:21 am
Dave
I'm more than happy to come up with tools too
Post by Rich H » Mon Sep 27, 2010 9:01 am
If your looknig for the jack then take these guys up on the offer!
The suspension isn't complex, but having someone who knows what they are doing with you the first time you jack it is priceless! :thumbsup
Post by j2 lot » Mon Sep 27, 2010 10:06 am
Post by Rag_It » Mon Sep 27, 2010 10:19 am
I wouldn't mind a hand, although I am sure with a bit of You Tube, and purchasing a trolley jack myself i could bodge it, enough to get it off the ground, take the wheel off, and take some photos....
StiflerMR2
Post by StiflerMR2 » Mon Sep 27, 2010 10:23 am
I have a bottle jack sitting in the garage if thats any use to you?
Post by robin » Mon Sep 27, 2010 10:49 am
NOOOOO never jack an elise with a bottle jack. Until you know enough to know how you might be able to do it safely, at least.
Post by Rich H » Mon Sep 27, 2010 10:52 am
Plus I doubt you'll get a bottle jack in.
A low entry jack is the best option but a normal floor jack will do.
The chassis needs protecting with either rubber or wood as the steel jack will damage it otherwise.
StiflerMR2
Post by StiflerMR2 » Mon Sep 27, 2010 12:15 pm
And this is why i always take my car to a garage :oops:
Dicey
Post by Dicey » Mon Sep 27, 2010 12:36 pm
Dave,
I have a trolley jack you can use - happy to come across and give a hand if need be.
Mike.
