Does anyone know of a supplier who would create a loom to link an S1 to the UK spec K20 with Hondata kpro ecu?
Failing that is there a list of all the connectors etc that you need? Maybe it is clearer when things are in bits...
Rob
The C101 is not waterproof and not designed to be in an Engine Bay. I use one plug for the bigger wires (Starter, +feeds to sensors) and one for the smaller sensor wires. Just the way I do itrobfitz wrote:Thanks Alan
Why did you replace the C101 with the two plugs on the right? My thought was to leave the Honda loom standard, though that is on the basis that you can get the relevant part that the c101 on the honda loom plugs into?
Rob
