StiflerMR2
by StiflerMR2 » Sat May 22, 2010 4:32 pm
So, I have my first trackday in the elise coming up and wanted to get a little feedback on recommended tyre pressures (at least for the start
The car currently has stock Bridgestones on (RE0A40's - I think the code is) and I currently have them set at the pressure as stated in the hand book (26F and 27.5R)
Whats the general concenus for pressures for track use on the stock tyres?
Thanks for any and all info.
-Mark.
- Barefoot Ninja
by tut » Sat May 22, 2010 4:48 pm
If you drive your car hard on track, tyre temps will increase far more than on the road. I bought an infra red thermometer for £12 recently, and that is your best bet.
As a general yardstick, I drop my pressure by around 4lbs to bring it back to the 19/21 that I use on my R tyres on the road.
steve_weegie
by steve_weegie » Sat May 22, 2010 10:43 pm
I'll second Tuts 4 psi drop as a general rule of thumb
The front left does most of the work at knockhill, so you may wish to drop it a further 1psi or raise the front right 1psi - which ever suits...
StiflerMR2
by StiflerMR2 » Mon May 24, 2010 9:34 am
Thanks chaps,
Was thinking about starting off with them around the 24F and 26R and seeing how I get on.
Thanks again for the input
-Mark.
Modena Scotland
by Modena Scotland » Mon May 24, 2010 9:43 am
I'd start at 24/26 as you said and come in after 7 to 10 laps. Check the pressure. They will be like 30/32 if dry. Take some air out if the car starts to understeer (as mentioned, the front works a lot thus the understeer).
May see you on the 27th.
Mass
A Senna
Shared SE Calendar
