The best track brake pads
- Modena Scotland
Guys, which pads do you recommend for track use on the CR (standard discs and calipers). I've been using RS14 front and RS42 rear but I need to get some new pads soon.
A Senna
Shared SE Calendar
Re: The best track brake pads
The Carbotech XP10s I have been using are excellent. The 10's might be overkill on the rears so will probably try XP10 front and XP8 rear next time.
I'd run them the other way round personally. 42s on the front and 14s on the rear.Modena Scotland wrote:Guys, which pads do you recommend for track use on the CR (standard discs and calipers). I've been using RS14 front and RS42 rear but I need to get some new pads soon.
Pretty difficult to beat Pagids.
Dan
- Modena Scotland
Dan why???? I had the 42s front and they didn't last long at all! 15s are lasting a lot longer.
A Senna
Shared SE Calendar
Its more to do with balance than wear Mass.Modena Scotland wrote:Dan why???? I had the 42s front and they didn't last long at all! 15s are lasting a lot longer.
dan
- Modena Scotland
Dan, I can't ignore the wear rate with the number of TDs I do
A Senna
Shared SE Calendar
- Modena Scotland
Has anyone tried the Carbone Lorraine pads?
A Senna
Shared SE Calendar
Mass, I thought that you just bought a new car when the pads wore out.
- Modena Scotland
Tut, you got me all wrong.......
A Senna
Shared SE Calendar
I've just fitted CL's on mine. Should get their first track outing at TTModena Scotland wrote:Has anyone tried the Carbone Lorraine pads?
Exige V6
- alicrozier
roadboy wrote:Its more to do with balance than wear Mass.Modena Scotland wrote:Dan why???? I had the 42s front and they didn't last long at all! 15s are lasting a lot longer.
dan
I've overheated 42s on the front Dan (and that was in in an N/A Exige), I'm sure Mass would do the same having witnessed his braking antics.
Agree with the balance though, even worse with 4 pots on the front...
For general interest...15s on the back...?
http://www.pagid-brake-pads.co.uk/mater ... ations.php
In that case Ali I would recommend bigger discs and with a large number of track days you'll save on pads and discs in the long run.alicrozier wrote:I've overheated 42s on the front Dan (and that was in in an N/A Exige), I'm sure Mass would do the same having witnessed his braking antics.roadboy wrote:Its more to do with balance than wear Mass.Modena Scotland wrote:Dan why???? I had the 42s front and they didn't last long at all! 15s are lasting a lot longer.
dan![]()
Agree with the balance though, even worse with 4 pots on the front...![]()
If you overheat 42s then I would recommend the following:
AP 295 discs on the front and AP290s on the rear. 42s on the front and 14s rear., Standard calipers will suffice with that setup. If that isn't sufficient then you're either doing it wrong or you have a lot of power/a very heavy car.
/2p
Dan
Oh, and I would never run 14s on the front of an ABS equipped Elise/Exige.
Dan
Dan
http://www.elise-shop.com/carbone-lorra ... 00031.html
The bite is the best I’ve had from a brake pad and it’s also the first brake pad I’ve had that doesn't give me pad displacement, caused mainly by overheating. They were great at the Nurburgring which has 3 very heavy braking points. No idea on wear rate as yet, but worth every penny for performance.
Only downside is they are loud.
Drop Yvo an e-mail there might be some SE discount to be had.
Tell him I sent you
- alicrozier
I think it's both now Dan.roadboy wrote:In that case Ali I would recommend bigger discs and with a large number of track days you'll save on pads and discs in the long run.alicrozier wrote:
I've overheated 42s on the front Dan (and that was in in an N/A Exige), I'm sure Mass would do the same having witnessed his braking antics.![]()
/2p
Dan
Current car has 308s on the front with 4pots now so could maybe try 42s on the front 14s rear (currently 14s all round).
I had some pad transfer on the first set of 14s but since skimming they have been fine...
