Resistor Pack Upgrade Installation
Has anyone got a copy of the technical service bulletin that comes with the upgraded resistor pack? Mine's arrived minus instructions
Exige V6
- Alex 111s
Re: Resistor Pack Upgrade Installation
same happened to me. I called murray's for a copy but 4 months later, I'm still waiting.
its quite staightforward.
clam off
disconnect a/c & heater pipes
split joint between fan & heater matrix
lift out heater matrix block
lift out fan unit
remove old resistor pack and cover hole with blanking plate provided & then apply sticky backed foam stuff.
remove interface plate with the two hooks on the bottom from the fan unit and replace with the new one provided. overlay foam stuff on the side that interfaces back onto the heater matrix.
remove plate on the heater matrix (drill out the pop rivets) and install the new plate (i used small set screws & nuts instead ofhte rivets supplied) with resistors in it's place. (resistors on the inside.)
connect up the orange/ black wires.
from here on in, it's just a case of reinstating everything back in reverse order.
there's a SELOC techwiki as well but it doesn't say much about the kit.
(PM'd you my home number if you need to talk any of it through)
hopes this helps
clam off
lift out fan unit
hopes this helps
Alex
Gone
111s In Magnetic Blue - Hofmann's Nitrons, Larini C.Sport, Huricane Induction, EBC Ultimax/Yellow Stuff, TD Pro-Race Wheels.
Gone
