Won't start - can't hear fuel pump
skellyjohn
Post by skellyjohn » Tue Apr 06, 2010 2:43 pm
My car's stuck at the house and I can't get it started. It turns over but doesn't start. The fuel pump doesn't sound like it's usual self - i.e. it's not humming before ignition.
Any clues? I'm supposed to be going down south tomorrow in it. I'm in the AA but don't have Home Start.
J
s1 111s (kind of)
Re: Won't start - can't hear fuel pump
Post by BiggestNizzy » Tue Apr 06, 2010 2:46 pm
Check the fuel pump fuse in the back
skellyjohn
Post by skellyjohn » Tue Apr 06, 2010 3:16 pm
Fuse looks ok.
s1 111s (kind of)
Post by Rich H » Tue Apr 06, 2010 3:28 pm
Immobiliser fault?
Post by BiggestNizzy » Tue Apr 06, 2010 3:30 pm
Press the fuel pump cutoff switch down
skellyjohn
Post by skellyjohn » Tue Apr 06, 2010 3:33 pm
Tried the fuel cut off thing -it was ok.
I don't think it turns over if it's immobilised so I dont THINK its that.
Thanks for the help. Keep the suggestions coming please!
s1 111s (kind of)
Post by BiggestNizzy » Tue Apr 06, 2010 3:38 pm
are you getting power across the fuse ? when it happened to me the fuse holder was rusty and had to be replaced.
other than that I am out of idea's
Gourlay83
Post by Gourlay83 » Tue Apr 06, 2010 3:57 pm
Check you are getting 12v accross the Fuel Pump Fuse. If ok, try a good known MFRU.
Alan
Post by Rich H » Tue Apr 06, 2010 4:25 pm
Mine cranks with the immobiliser off... but I think mine is special.
MFRU is a good call though.
skellyjohn
Post by skellyjohn » Tue Apr 06, 2010 6:24 pm
I checked the fuse and it's getting 12v to it.
Still no joy and its raining again...
s1 111s (kind of)
Post by Rich H » Tue Apr 06, 2010 6:50 pm
Sounds like the MFRU then - well known for failing suddenly - Shug killed one recently IIRC. Standard Rover part.
skellyjohn
Post by skellyjohn » Tue Apr 06, 2010 8:20 pm
I gave the mfru a shake and now I'm getting absolutely nothing - not even turning over. So it's maybe looking like that or the wiring into it.
s1 111s (kind of)
skellyjohn
Post by skellyjohn » Tue Apr 06, 2010 8:23 pm
And thanks for the other advice Ross :thumbsup
s1 111s (kind of)
Gourlay83
Post by Gourlay83 » Tue Apr 06, 2010 9:04 pm
MFRU contains the starter relay as well so I would replace it or test your input and output voltages.
Alan
skellyjohn
Post by skellyjohn » Sun Apr 11, 2010 11:37 pm
Still not starting.... :(
I swapped the mfru over and still nothing.
So apart from the fuel pump, I think I've checked everything that's been suggested. Are there any fuses in the front of the car I should be looking at? (please bear in mind I'm the guy that takes my car to a garage when it needs a new wiper blade!)
s1 111s (kind of)
