Scottd
by Scottd » Fri Jun 23, 2006 1:19 pm
As I'm breaking to about 10-5mph, I feel the car speed up, slow down, speed up, sort of pulsing, it's hardly noticable at all (passengers can't tell)... but I notice it. There's nothing strange about the feel from the pedal but can tell the car's not coming to a stop correctly.
Fairly new pads and discs but it is time to change the brake fluid, could it be that?
cheers
scott
by Shug » Fri Jun 23, 2006 1:21 pm
If it's really low (like walking) pace, maybe uneven build up on the discs? Can't see how fluid would make it pulse...
If so, try re-bedding. If that doesn't sort it, get the discs skimmed.
Tom
by Tom » Fri Jun 23, 2006 1:25 pm
Scottd wrote:As I'm breaking to about 10-5mph, I feel the car speed up, slow down, speed up, sort of pulsing, it's hardly noticable at all (passengers can't tell)... but I notice it. There's nothing strange about the feel from the pedal but can tell the car's not coming to a stop correctly.
cheers
scott
I've got exactly that as well scott. newish disks and pads, but car had a soft life before me. will try bedding properly. Let me know how you get on.
1995 Volvo 940SE Estate
Scottd
by Scottd » Fri Jun 23, 2006 1:27 pm
Yea, it's at walking pace, so slower than I said really. An uneven build up? of what?
I'm not sure if it does it all the time either, I'll keep an eye on it.
by Shug » Fri Jun 23, 2006 1:30 pm
When you bed pads in, what you are doing is transferring pad material into the structure of the disc. If it's not done right, or the discs are overheated and sat with the pads on them, the build-up is uneven and can cause what most people will call a warped disc.
by Stephen » Fri Jun 23, 2006 4:11 pm
Have your brakes ever bound on or do you have a pad shaped mark on your disk?
This often happens causing a wee rusty bit that would give the feeling that you describe. As the disk rotates and the pads rub on a rusty bit then smooth bit etc
Scottd
by Scottd » Fri Jun 23, 2006 4:29 pm
I'll take a better look at them later tonight.
Uldis
by Uldis » Sat Jun 24, 2006 8:15 am
Uneven pad build up or in new disks could be just the manufactuing tolerance.
Whatever the cause, you have a varying disk thickness so for the same pedal travel you have a place with more pad pressure and a place with less.
Apartfrom skimming, nothing you can do, and unless it's very bad it's not worth it.
DIY recipy to wear out the thick spots: a healthy track sesson
If that doesn't do it, then another one
Lawrence
- Jedi Master
by Lawrence » Sat Jun 24, 2006 10:04 am
Some very intresting reading here especially this which may be tut's problem
by Stephen » Sat Jun 24, 2006 10:58 am
lawrence,
that should'nt be a problem with MMC's though should it?
Lawrence
- Jedi Master
by Lawrence » Sat Jun 24, 2006 11:25 am
Stephen wrote:lawrence,
<Sherlock_Holmes> We must fall back upon the old axiom that when all other contingencies fail, whatever remains, however improbable, must be the truth.</Sherlock_Holmes>
