Heater Matrix/blower assembly
whaleys
Post by whaleys » Mon Feb 22, 2010 9:55 pm
Evening chaps/chapesses,
I have what seems to be the common problem of the resistor pack going on the heater, the fan is only operating at numbers 2 and 3. I did some reading an it seems straight forward, buy a new resistor pack or the new "upgraded" one. Access it via the passenger service panel or clam off and job done. I have a 2002 Elise and it doesn't seem to be that straight forward. My heater blower is not located below the passenger service panel its central to the car. It would also seem that the blower, matrix, and resistor block are one unit.
The heater fan has also been getting a bit noisy so I had figured I would just replace the fan and the resistor unit, it seems this will not be the case. I'm hoping that someone can give me some super advice that means I'm not going to have to replace the whole shooting match :( but I'm thinking that's probably just wishful thinking.
Does anyone have any experience with these units and any money saving advice? (someones going to say just leave it broken :)) It's just from what I can gather its a REALLY expensive part.
Thanks,
Graeme
edit: I have some blurry photos if it helps
DavieK
Re: Heater Matrix/blower assembly
Post by DavieK » Tue Feb 23, 2010 9:29 am
Dont know if the S2 is the same as an S1 but when ours was noisy it was the fan rubbing on the flap that controls the amount of air going through the matrix. I just drilled a hole slightly further out on the control arm so that the flap didnt move as much and the noise stopped.
Stumpy Nugget
Post by Stumpy Nugget » Tue Feb 23, 2010 10:19 am
I have not had to play with this part of the car yet but if it is this part you are talking about replacing
http://www.eliseparts.com/products/show ... trol-unit/
Then I think I will be looking to see if I could also find a cheaper way than spending 111 quid also. Nothing on SELOC? I am sure someone there has built one out of bottle tops and a TV remote control. :wink:
Polo Blue motion - Eco Warrior Spec
2001 Maroon S2. Loud money pit spec.
cstrachan
Post by cstrachan » Tue Feb 23, 2010 10:21 am
If it is the same as the VX220 heater (most likely is) then have a look on vx220.org as loads of people are upgrading and fixing heaters at the moment, plenty of threads about soldering and replacing the resisters also.
2003 Vauxhall VX220 2.2
2013 Astra BiTurbo
2015 Fiesta Ecoboost
Stumpy Nugget
Post by Stumpy Nugget » Tue Feb 23, 2010 10:27 am
Found this.. Talks about ohms and things, must be right then. "I do science me".
http://forums.seloc.org/viewthread.php? ... pid4375494
whaleys
Post by whaleys » Tue Feb 23, 2010 10:55 am
Stumpy Nugget wrote:Found this.. Talks about ohms and things, must be right then. "I do science me".
You're on to something with that thread on Seloc. The heater unit described is the same as mine.
cstrachan wrote:If it is the same as the VX220 heater (most likely is) then have a look on vx220.org as loads of people are upgrading and fixing heaters at the moment, plenty of threads about soldering and replacing the resisters also.
I never even thought to check the VX220 forum :oops: .
The VX220 does have the same heater unit for anyone else having the same issue as me here is a good thread:
http://www.vx220.org.uk/forums/index.ph ... ntry991863
DavieK wrote:Dont know if the S2 is the same as an S1 but when ours was noisy it was the fan rubbing on the flap that controls the amount of air going through the matrix. I just drilled a hole slightly further out on the control arm so that the flap didnt move as much and the noise stopped.
That may be what is causing the rubbing noise I'll be able to take a look at it when I take it apart. Either way I'm not so worried about it now, was concerned as I was getting signs of prices around £650 just for the replacement part! but it looks like I will be able to fix it myself.
As always, thanks very much,
Graeme
cstrachan
Post by cstrachan » Tue Feb 23, 2010 11:06 am
Glad it helped :D
.Org has lots of good how too's and most will be the same or simlar to the elise :thumbsup
2013 Astra BiTurbo
111Rxpress
Post by 111Rxpress » Wed Mar 10, 2010 4:36 pm
just for info, my 2005 S2 has had the thumbs up for some warrnety work rgds this problem. my heater would not blow on settign two, but was okay on one and three. anyway is covered under warrnety and that was lucky as the bill was +£500 !! are Lotus mad?
Rgds
Robert
delands
Post by delands » Sun Mar 28, 2010 11:47 am
Its the labour that puts the Lotus price up as they take the clam off.
New blower units have drain holes in them to stop water damage, so if replacing resistor only, drill a few holes!
http://www.elise-shop.com/heater-fan-re ... p-312.html
http://www.elise-shop.com/heater-fan-re ... p-771.html
DEL
2022 Hyundia i10 N-Line
2019 DS3 Crossback
neil
Post by neil » Sun Mar 28, 2010 3:31 pm
There's a guide on how to do the resistor pack with the clam on here - http://www.scottishelises.com/phpbb/vie ... =5&t=16457
Exige V6
