4pot k + autobox
thinfourth
4pot k + autobox
Post by thinfourth » Sun Jan 10, 2010 11:41 am
After seeing a very silly offroad toy i am wandering if the k-series every came with a auto box?
Re: 4pot k + autobox
Post by robin » Sun Jan 10, 2010 12:13 pm
Pretty sure there is a 218 automatic ...
Post by BiggestNizzy » Sun Jan 10, 2010 1:40 pm
There was a CVT box on the MGF, it could imitate gears but was essentially a CVT
Steptronic it was called, had a full auto and flappy paddle setup. If it was a better box 9although alot of that was probably software) I would love one in an elise but without the flappy paddles just plane old cvt
http://www.youtube.com/watch?v=LlWYTnaDnK0
http://www.youtube.com/watch?v=ABaJidk9SJA
Post by Rich H » Sun Jan 10, 2010 5:00 pm
8) CVT would be ace :mrgreen:
Looks tiny but is apparently rev-limited and couldn't cope with the VVC - I suspect it's power limited..
http://cgi.ebay.co.uk/1996-MG-F-1-8-16V ... 588200685f
Apparently slower than a manual but would surely be down to the software being crap? I suppose it has a torque converter??
Add a manual clutch for starting off and some funky software then sit in the power band all day long and just change ratio??!
(EDIT Looks like it has a normal clutch throwout bearing?!)
thinfourth
Post by thinfourth » Fri Jan 22, 2010 9:09 pm
Figo
Post by Figo » Mon Jan 25, 2010 1:33 pm
Done a bit of raking..
According to the MGF workshop manual the Steptronic has a VT1-11A gearbox. The 2001 MGF Sales Brochure says that a Steptronic (called Stepspeed in the TF due to BMW owning steptronic) has a maximum torque of 165Nm @3000 rpm and 120Ps @ 5500 rpm.
There are the three models of CVT gearbox that ZF make:
Type VT1 capable of 165 NM = 121.7 ft.lb
Type CFT 23 for max 250 NM = 184.4 ft.lb
Type CFT 30 for max 310 NM = 228.6 ft.lb
As fitted to the MG, the CVT 'box is already at the limit of what it will take in regards to the engine's torque output.
I had thought that the uprated design was fitted to the BMW MINI, but as far as I can find out the MINI uses the VT1 box in its VT1-F form.
Not a scooby if the MINI Cooper S variant comes with a CVT box. If it did then I would assume it was fitted with the stronger CFT 23 or CFT 30 types, seeing as the Coop S produces 240 NM @ 1600 rpm and 175bhp @ 5500 rpm. Could be something to look into.. I know a few folk running NOS on their MG's were looking into the Mini Gearbox a while back. :cheers
Post by BiggestNizzy » Mon Jan 25, 2010 1:35 pm
Rich H wrote: Apparently slower than a manual but would surely be down to the software being crap? I suppose it has a torque converter??
It has a torsional damper insyead of a torque converter, they do appear to be slower than a manual box (0-60 time is slower)
More info here
http://www.mini2.com/cvt/zf_vt1f_gearbo ... iption.pdf
http://www.mini2.com/forum/attachment.p ... 1097680293
you cannot tow a car with this type of gearbox (may rule it out for the elise :P)
the modern mini's come with a getrag 6 speed auto box
Post by Rich H » Mon Jan 25, 2010 1:48 pm
:thumbsup nice find!
Are those other boxes bolt-on fits?
Post by BiggestNizzy » Mon Jan 25, 2010 2:07 pm
They should "bolt on" reasonably easily as they are fitted to MGF steptronics but they are software controlled, that is what might cause the problems.
Post by Rich H » Mon Jan 25, 2010 6:00 pm
Where is Robin when you need him! :lol:
Could be 'interesting' to tune :lol:
The interesting bit will be the initial start off, how do you get engine revs/gearing to work together. I would think you could have a hand throttle - 3 settings: idle/start, max torque, max economy
Might get very tiring though having the lump buzzing at 4.5k rpm all the time though!
Post by BiggestNizzy » Tue Jan 26, 2010 10:58 am
I would love to fit one in the car like you say a switch on the car to set whatever mode you want, the only problem I ccan see it the gearbox is setup to simulate gearchanges because "thats what the public want" when the throttle is depressed more than 85% it will "kickdown" for a race/track application it would work well.
Alas it will always be out of favour until the technology is used on track and that will never happen.
Post by Shug » Tue Jan 26, 2010 11:03 am
BiggestNizzy wrote:I would love to fit one in the car like you say a switch on the car to set whatever mode you want, the only problem I ccan see it the gearbox is setup to simulate gearchanges because "thats what the public want" when the throttle is depressed more than 85% it will "kickdown" for a race/track application it would work well.
It wont' happen, as it's actually prohibited in most race regs. Pretty much everything specifies a fixed number of fixed forward ratios. I agree on the technical advantages of CVT, but jesus, it'd be boring to listen to...
moooooOOOOOOOOOOOOOOOO (repeat until catatonic) :mrgreen:
Post by BiggestNizzy » Tue Jan 26, 2010 11:27 am
I think it was williams who tried it in F1 and even before a race it was banned. half the problem with F1 is the lack of inovation nowadays as the regs are so tight it's all a variation on a theme.
The sound thing wouldn't bother me and I get bored changing gears, maybe I'm getting old though.
Post by Rich H » Tue Jan 26, 2010 1:27 pm
Shug wrote:moooooOOOOOOOOOOOOOOOO (repeat until catatonic) :mrgreen:
Agreed it would sound properly sh!t but imagine the surprise when you zip off into the distance without a change in engine note and without evidence of a gearchange!
Would need to be silenced in the extreme though. Also you would need some sort of start off thing that didn't dump the clutch...
Can't believe they couldn't get the 0-60 down - there is an instant half+ sec advantage to not having to change gear!
Post by BiggestNizzy » Tue Jan 26, 2010 1:39 pm
I am suprised also apparently the williams CVT was several seconds a lap quicker and yes you would have to put a quieter exhaust on it as you would in effect go everywhere (when in sport/race mode) at full chat.
The Nissan CVT look a better bet too.
http://www.youtube.com/watch?v=x3UpBKXMRto
