Does the Duratec need a dry sump? Well, general opinion is that the Raceline wet sump (the one the R400 comes fitted with) is good enough for road tyres. But I found the long brake in to the hairpin at KH did challenge the system - it was OK if you kept it clean, but get it wrong or spin and oil pressure drops.
Click image for big version
This shows the problem. It is the ECU download of 'lowest seen oil pressure'. When the car was new it followed the grey line but as the number of trackdays increased it recorded more low pressure events. Caterham have suggested a check/swap of big end bearing and I hope to give the engine a once over for wear/damage and also fix a noisy tappet.
The bits . . . . .
It is an internal, two stage chain driven scavenge pump made by Titan to the Cosworth design and it uses OE pressure pump. Caterham now use the single pump Raceline unit that replaces the OE unit. It is probably more reliable (less parts) but being smaller, must have a smaller capacity.
I'll post progress/disasters/failures over the next few weeks.
David
