Rear A048s
Rear A048s
How long is everyone getting out of a set of A048s on the rear? I've done about 3200 miles on my current set and they are just about to hit the markers. I've done one trackday and 2 or 3 proper 'runs'. I'm quite surprised as on the run yesterday i found the grip in the wet fantastic once the tyres had warmed up. I'm going to buy new ones, but should i keep these as spares for next years trackdays?
2008 VW Golf R32
2013 BMW 330d X Drive M Sport
Re: Rear A048s
it really depends how u drive and where. I can get anywhere between 200 miles on track and 8000 miles on the motorway.
If u think they're wearing out too quicky, get ur geo checked. Too much rear toe will kill them quickly.
Re: Rear A048s
That doesn't seem like that much usage ... the 888's we fitted for FF this year did the full 3000+ miles of hot FF including 3 track days and some very spirited mountain roads, then another 2000+ miles including a few laps of the ring and a complete day at Spa. They are now on the wear markers, but even so that sounds like a lot more miles/use that you have got out of the A048s. I don't do much
Is the wear even across the tyre, outside (too much toe in), inside (too much camber), centre (overinflated) or both edges (underinflated)?
Re: Rear A048s
I got roughly 3500 out the rears on mine before i changed them, that was with two track days and a few runs.
Kevin.
Kevin.
07 Exige S Sports with 2bular
Re: Rear A048s
Robin, the wear is even right across both tyres. The geo was done not so long ago when i got new rear track rod ends. I check they are correctly inflated fairly regularly. Will need to find my tread depth indicator which i seem to have mis-placed in my garage.
I'm sure someone said that the rears were good for 6000 and the fronts for 9000?
2008 VW Golf R32
Re: Rear A048s
If they're worn even then they've done their job. The only way you'll make them wear less is to use less right foot/avoid donut/wheelspin/etc.
Re: Rear A048s
P.S. A lot of people find that they use two sets of rears to one set of fronts; the elise is a pretty light car and unless you constantly drive the car into understeer, the front tyres don't wear all that quickly, so perhaps they were saying you'll get 6-9 out of a set of fronts, which is not out of the question.
Re: Rear A048s
If they've not hit the markers yet then you'll probably get another 1000 out of them. Get your tread depth gauge on them - 1.6mm is still legal and I think the markers are at 2ish
Exige V6
Re: Rear A048s
Ah wish i had known this that they were still legal after being on the marker level, mines were a tad above marker level when i changed them, as expected to have worn them out on knockhill but didnt have as much wear as expected due to it being very wet.neil wrote:If they've not hit the markers yet then you'll probably get another 1000 out of them. Get your tread depth gauge on them - 1.6mm is still legal and I think the markers are at 2ish
Oh well still got them in the hut.
Re: Rear A048s
were you running "lts" spec 48's?
You could try MH compound instead which is a bit harder and makes very very little difference to performance, but should give you more miles
The LTS are equivaklent to the normal M compound i believe - thats what we race on in the LOTRDC.
Ronnie at WheelsAround is your man to speak to - tell him AndyG sent you
Re: Rear A048s
If the markers are at 2mm, then maybe i've got more tread left than i thought. I just assumed these were at 1.6mm. They are LTS spec.
1 hour and 20mins must be a record Scotty! Certainly don't drive as hard on them as you.
2008 VW Golf R32
- alicrozier
Re: Rear A048s
Think you might need to look at your slip angles...Scotty C wrote:oh 1 hour 20 minures of qually and racing
Re: Rear A048s
That's not big and it's not cleverScotty C wrote:oh 1 hour 20 minures of qually and racing
(that's why I think Mike will do fine, that and his lack of imagination).![]()
Re: Rear A048s
Poofs - 8 sets in a year (4.5k vaguely) in the Atom, no racing (well apart from FF)alicrozier wrote:Think you might need to look at your slip angles...Scotty C wrote:oh 1 hour 20 minures of qually and racing
