How much brake fluid for a full drain flush and change?
Post by Victor Meldrew » Fri Jul 24, 2009 11:28 pm
Brake fluid boiled at knockhill after 15 laps.. No pad fade at all with Carbon Loraine pads and AP disks..
I was planning to change out the brake fluid, which is probably over a year old now for a higher spec competition version.
The "racers choice" is £50 a litre.. which for a once a year change on car that takes a real hammering I suppose isn't to bad.
However, if the esteemed wisdom reckons that I will need two litres to do a full drain & flush (£100) the the cheaper stuff beckons.
Re: How much brake fluid for a full drain flush and change?
Post by mckeann » Fri Jul 24, 2009 11:38 pm
I reckon your better just flushing the normal fluid more often, than the super duper stuff once a year
fd
Post by fd » Fri Jul 24, 2009 11:43 pm
Never boiled brake fluid in the Elise, thousands of laps of KH, 175bhp engine, late braker . . . used/use Castrol Super DOT4 changed once a year . . . 50 quid a litre is a waste of money
$0.02
Fd
Post by Mike Scib » Fri Jul 24, 2009 11:55 pm
RBF 660 :thumbsup
http://s2.pegasusautoracing.com/2008/140.pdf
Have a look at the second half of the link.
ClarkyBoy
Post by ClarkyBoy » Sat Jul 25, 2009 12:14 am
Victor Meldrew wrote:Brake fluid boiled at knockhill after 15 laps.. No pad fade at all with Carbon Loraine pads and AP disks..
i just flushed out my full system tonight, as i boiled the s2 on standards pads+disc coming over applecross on 050709, lost all brakes for around 30 miles, the handbrake became a very good mate!
you would be right on needing around 2 litres to flush the system, what i would suggest is you flush out the fluid on each corner, starting n/s rear, then n/s front, then repaeat for far side, until you are pulling through new fluid, i used dtandard cheap fluid - didnt see the point in wasting good stuff to cleanb the pipes, my next step is to replace with this stuff,
http://shop.instant-shop.com/JRT-Automo ... 30649.html
Ate fluid, alot cheaper per litre and still very high quality
to fill the s2 from empty you are looking at 3/4 of a litre - so i was told buy the guys @ MMC
anyway, hope this helps you - oh and dont break a bleed nipple like i did, anyone got a spare for the front (need to drill mine out!)?
Vanlife Sprinter
E30 318is / axle stand spec
987.2 Cayman S
[#]=///=[#] ‘88 Panda 4x4
BSA B31
MF35
Stiga Tornado
Many Bicycles
Post by Mike Scib » Sat Jul 25, 2009 12:15 am
:lol: :lol: You been drinking by chance Kenny :shock:
Post by kenny » Sat Jul 25, 2009 12:17 am
I don't know what you are talking about Mike?
Tee total as you know.
:mrgreen:
Post by Mike Scib » Sat Jul 25, 2009 12:22 am
kenny wrote:I don't know what you are talking about Mike?
:mrgreen:
Que drunk pic of kenny lying on the floor.......
Post by kenny » Sat Jul 25, 2009 12:25 am
Off topic. Ban for Mike :thumbsup
neil
Post by neil » Sat Jul 25, 2009 12:27 am
:mrgreen:
:shock: Whatever floats your boat! :lol:
Exige V6
Post by Victor Meldrew » Sat Jul 25, 2009 2:55 am
fd wrote:Never boiled brake fluid in the Elise, thousands of laps of KH, 175bhp engine, late braker . . . used/use Castrol Super DOT4 changed once a year . . . 50 quid a litre is a waste of money
$0.02
Fd
Kind of what I thought, why I asked the question first rather than diving in and buying some..
Post by tut » Sat Jul 25, 2009 8:17 am
I put ATE super blue in a year ago as well and never had a problem with boiling or brake fade.
philthy
Post by philthy » Sat Jul 25, 2009 1:23 pm
changed mine with cheap Halfords 5.1, did the job superbly.
the old stuff that came out-
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
