bigdek
by bigdek » Fri May 01, 2009 10:38 pm
picked up the wifes s2 elise today.
all appears well and the 420 mile drive home was more comfortable than expected.
however the heater control knob that should turn from hot to cold is rock solid.
is this common ? what does the knob control ? is it just a flap ?
how do i get into it to sort the problem
wife loves the car
tenkfeet
by tenkfeet » Fri May 01, 2009 10:48 pm
If its an early S2 ( I assume) they are cable operated . You may just need to lubricate your flap.
If the cable is seized I am not sure how you get into it . The manual says you need to remove the facia top ???? Hopefully someone who has done it will be able to explain better .
You have a PM .
No lotus
Exige Sport 350 (Sold)
Evora S (sold)
- Jedi Master
by robin » Fri May 01, 2009 11:24 pm
I didn't think any S2 was cable operated - I thought that my original S2 (X reg) had a cable operated system when the switch was too tough to turn ... but then there were no cables ... or am I dreaming all this - was a long time ago!
Kayfur
by Kayfur » Fri May 01, 2009 11:53 pm
My 2003 135R is definitely cable operated.
Kevin
Exige S
Caterham 7
- Jedi Master
by robin » Sat May 02, 2009 9:08 am
Ah - mine must be too then - never looked
Cheers, Robin.
tenkfeet
by tenkfeet » Sat May 02, 2009 10:06 am
My 03 MY04 is electrical .
No lotus
Evora S (sold)
bigdek
by bigdek » Sat May 02, 2009 4:18 pm
itsa a 2002 51 .
had a wee look and its a cable.
flap was jammed but now its free and working fine.
cheers
tenkfeet
by tenkfeet » Sat May 02, 2009 4:37 pm
bigdek wrote:itsa a 2002 51 .
cheers
Jobs a carrot .
No lotus
Evora S (sold)
