My flexi section is bust tho (it failed on that too), could this be affecting the lambda reading?? :-/ Was planning on fitting a new fexi soon anyways.
cheers
scott
To clarify, even though your car has a lambda sensor, the MOT tester is not checking your lambda sensor but rather the O2 content of the exhaust. As you have a hole in the exhaust the extra air that is drawing in is making the O2 content wrong. Having said that, I cannot see why it would fail on too much O2 ... as we discussed on the telephone, what's probably going to cause you to buy a new Lambda sensor is the fact that you'll end up changing in the exhaust manifold and the old one won't come out withough WMD ..Scottd wrote:It only failed on the Lambda reading, the CO and HC were fine. Do I need a new lambda sensor?If so where's the cheapest, Rover in Dundee want over £100
Not entirely sure it's the right one tho.
cheers
scott
And you think AC is the best place to take it?Bennicus wrote:Out of interest, where are you getting your MOT done, Scott? The Arnold clark MG/rover place just off the Kingsway? I'm due an MOT in a month or two and would like a garage that won't destroy my beautiful beautiful car.
Nah, I tend to avoid official dealerships like the plague, the only reason I asked about that place was because Scott mentioned they wanted £100 for the sensor, wasn't really sure if that implied he was getting the MOT there too. I'll bear the proton d****r & Fairfield Road place in mind tho, cheers!simon wrote:And you think AC is the best place to take it?Bennicus wrote:Out of interest, where are you getting your MOT done, Scott? The Arnold clark MG/rover place just off the Kingsway? I'm due an MOT in a month or two and would like a garage that won't destroy my beautiful beautiful car.
Avoid at all costs or you WILL regret it
I've said before about servicing and didn't know if they done any but I know that the Proton dealer has definately done MOTs on Elises. There's also the place that Lee recommended on Fairfield Road I think but dunno if they do MOTs. A guy at work also told me he saw an Elise in a garage near the Mosque down from the Globe, can't remember the name of the place tho.
Dundee - Dunfermline = 30 mins, not that much of a trekandysc wrote:Had the same problem with mine a few months back, Co2 high.
Got the new lambda for 40 bucks from a motor factors & also found holes in exhaust. Changed both just to be sure. Lambda is an interesting job, be prepared to bleed profusely. I think it was just the exhaust but I thought I'd best be sure as its a pain having to go back for the third time if it fails again!
got lambda from WD autofactors in Dunfermline. A bit of a treck from Dundee though.....
Andy
Rich last time I looked at mine it was the same, but the Elise Parts exhaust has been vibrating the fek out of it. It certainly sounds much worse now anyways.RICHARDHUMBLE wrote:Scott how busted is your flexi? I have one with a knackered mesh bit that tizzes a bit, but it looks gas tight if you want it.
Yea I wouldn't touch Arnold Clark. I'm going to a place that used to be very 'friendly' but now due to all the computer stuff they have to do, it's just like going anywhere elseBennicus wrote:Out of interest, where are you getting your MOT done, Scott? The Arnold clark MG/rover place just off the Kingsway? I'm due an MOT in a month or two and would like a garage that won't destroy my beautiful beautiful car.
At what speed?!simon wrote:Dundee - Dunfermline = 30 mins, not that much of a trek
