http://www.scottishelises.com/phpbb/vie ... &sk=t&sd=a
The problem's now back with it dying twice in a week (once in the Clyde Tunnel and last night in the outside lane of the M8 in heavy traffic
Ironically I was driving it back from a C service and MoT pass that required no extra work (first time ever!) and had told the garage about it but they couldn't reproduce it.
So I have to take it back on Tuesday to be fixed and it would be great to go armed with a theory or two of what it is. Suggestions so far: dodgy fuel pump or leaky inlet gasket.
Full symptoms:
Drives fine normally and will sit in traffic no problem when the engine is cold.
Fuel pump does the usual noises when the key turns (although has on occasion made very strange sounds at the same time).
Sitting in heavy traffic after a long motorway run (so everything is up to temperature) it will just stall without warning (usually when applying some throttle as compensating by pressing on the throttle is how I notice that the pedal is not, actually, doing anything and the engine is dead).
Fails to restart (although the starter turns, it just doesn't catch)
After waiting about 5mins it will catch but if it's not allowed to cool down sufficiently it will die fairly quickly.
Help!
