S1 Tyres
Re: S1 Tyres
Think people recommend t1r's for daily use. I am just saving for new tyres and brakes for my s1 elise.
1999 S1 Elise 111S - Fun Spec
Re: S1 Tyres
Can't go wrong with T1Rs in standard UK weather. Cheap and cheerful.
If you want more performance though you need to spend more! Camskill will get you a set of 4 T1Rs for under £300 (IIRC)
- Victor Meldrew
Re: S1 Tyres
Rich H wrote:Can't go wrong with T1Rs in standard UK weather. Cheap and cheerful.
- alicrozier
Re: S1 Tyres
I think Lotus recommend the Yoko C-Drive
http://www.pistonheads.com/lotus/defaul ... ryId=14825
http://wiki.seloc.org/a/Tyres
S1 Tyre Options (depending on your rim width I guess) :
Toyo T1-R
Yokohama C-Drive
Yokohama Advan Neova LTS
Yokohama A048
Hankook RS-2
Toyo R888
Dunlop SP9000
Falken Ziex ZE-512
Kumho Ecsta Sport KU31
Toyo T1-R
Yokohama C-Drive
Yokohama A048
Hankook RS-2
Toyo R888
Dunlop SP9000
Falken Ziex ZE-512
Re: S1 Tyres
R888 is a track tyre though - agree it can be fine on the road, but won't see the mileage a road tyre will and of no use if the car isn't driven on track IMO.
Re: S1 Tyres
PS- if you're running 11 year old P Zeros (congrats for not crashing) then even relatively 'cheap' T-1Rs will seem like a total revelation. The Zeros will be damn near solid by now. Good reports about the Kumhos at the end of Ali's list as well - even cheaper option.
- tuscan_thunder
Re: S1 Tyres
Only if you use them properly - the toe links won't spontaneously break
But yeah - if you were at the stage of using 888s or 48s on track properly, toe links are a must (having previously not bothered and subsequently had one let go on the road, I know what a hole it makes in your seat...)
Point is, track tyres are not needed on a car which obviously doesn't see a lot of high-speed cornering (as it's not in a hedge with the tyres it's got)
Re: S1 Tyres
Shug wrote:PS- if you're running 11 year old P Zeros (congrats for not crashing) then even relatively 'cheap' T-1Rs will seem like a total revelation. The Zeros will be damn near solid by now. Good reports about the Kumhos at the end of Ali's list as well - even cheaper option.
I'd say they are pretty similar to T1Rs, but better in standing water, and also a bit less road noise in the dry. They're not great for the first 1000miles (but T1Rs are horrendous for the first 1000). So far only driven in winter on crappy/wet roads so never got any heat in them. Would like to get them on track to see how they compare to the T1Rs though....
HTH
1995 Volvo 940SE Estate
Re: S1 Tyres
Thank's for the info'. Not bothered about looking for a budget tyre, I'd rather have the best performer for normal road use. I presumed the Advan Neova LTS having been specifically designed for the Elise would be the best option. Are the other tyres available not simply the correct size but not necessarily specifically designed for the Elise (ie. wall stiffness) ?.
Re: S1 Tyres
Neova LTS is the best option (if they are available) although Lotus now recommend the C-Drive (again, as per Ali's post) as a direct P-Zero replacement. FWIW, I'd go Neova. SE discount through MMC.
Re: S1 Tyres
No brainer. Stunner Scudos. Last for ever and used in the Scottish Championships.
OK, only by me........
- alicrozier
Re: S1 Tyres
Yup, I think the Yoko C-drive are also LTS code so specifically developed for the car though. C-Drives newer technology??? Neovas probably more proven history??? For your usage Robin I don't think you'll go wrong with either - inerested to see the price comparison.Shug wrote:Neova LTS is the best option (if they are available) although Lotus now recommend the C-Drive (again, as per Ali's post) as a direct P-Zero replacement. FWIW, I'd go Neova. SE discount through MMC.
Either will be a big improvement on the P-hero's...
Re: S1 Tyres
Stick with the P Zeros.........they are just coming to their best at that vintageShug said
BMW Z4M40i
Range Rover Velar
2022 Spec Mini JCW
BMW R9T Scrambler Sport
Honda 250 Race Quad
Womaniser Liberty
BMW Z4M40i
Range Rover Velar
2022 Spec Mini JCW
Honda 250 Race Quad
Womaniser Liberty
