IIIR engine lights and recover mode
Post by Andy G » Mon Apr 24, 2006 11:21 am
My 111R is still not feeling the love after Friday night - got the recovery mode thing re-set on Saturday morning, for another engine light to come on last night...whoops! (its the bottom left hand side one!)
They ran a diagnostic on Sat, and didn't seem to be any issues.
Anyone had any similar yota issues?
Serves me right for showing it no mechanical sympathy for 2 hours on Friday.
Post by Shug » Mon Apr 24, 2006 11:21 am
It's protesting at not being driven enough.... :thumbsup
Post by Andy G » Mon Apr 24, 2006 11:29 am
Trust me, I don't think thats the message it was giving me when the diagnostic equipment was plugged in......closer to WTF are you doing to me!
Seems to be running fine, slightly concerned.
Worth unplugging the battery and letting the EM reset itself?
I've actually got it at work today :D
Post by Shug » Mon Apr 24, 2006 11:32 am
Have no idea with the 'Yoda setup (oooh, recover safely, you will)
Soz mate, too newfangled for me :lol:
Post by GregR » Mon Apr 24, 2006 1:16 pm
Andy G wrote:Trust me, I don't think thats the message it was giving me when the diagnostic equipment was plugged in......closer to WTF are you doing to me!
sure your pax wasn't putting "little Pierre" somewhere he shouldn't? :wink:
Tom
Post by Tom » Mon Apr 24, 2006 1:45 pm
:lol: :lol:
ironside
Post by ironside » Mon Apr 24, 2006 3:09 pm
GregR wrote:sure your pax wasn't putting "little Pierre" somewhere he shouldn't? :wink:
As in fizzy water?
Simon
Post by mac » Mon Apr 24, 2006 3:34 pm
That's perrier :roll:
Post by Andy G » Mon Apr 24, 2006 6:24 pm
GregR wrote:[
I know Pete claimed to be enjoying the outing, but I'm hoping not that much :shock: :shock:
Post by robin » Mon Apr 24, 2006 7:08 pm
Is the car in warranty?
Post by Rich H » Mon Apr 24, 2006 11:53 pm
Does the warranty cover bouncing off the limiter while hooning around a track? :lol:
Did you try the IT fix of taking out the battery?
Post by Andy G » Tue Apr 25, 2006 12:03 am
just out of warranty and havent touched the battery first.
MMC have been good at checking the diagnostics so far :D
Post by robin » Tue Apr 25, 2006 8:35 am
RICHARDHUMBLE wrote:Does the warranty cover bouncing off the limiter while hooning around a track? :lol:
It does provided you don't over-rev on downshift. The toyota has a rev limiter that reduces engine speed if you hold it on the limiter - so you can bang it up to full RPM provided you shift up the moment you get there - if you hold it there it drops by ~200rpm to preserve the engine.
The engine is very fragile above it's maximum rev limit and it is not unheard off to crack a rocker arm if you change down too aggressively. However, that leads to very noticeable rough running and an inability to rev, as well as one cylinder having a massive fuel trim compared to the other three (which shows up on the Lotus Check tool).
The over-rev will be recorded in the ECU statistics also I believe, and if there is evidence of over-revving the warranty on the engine is obviously void.
Post by Rich H » Tue Apr 25, 2006 9:12 am
robin wrote:crack a rocker arm
:scratch Yota has rocker arms?
Post by Shug » Tue Apr 25, 2006 9:33 am
Part of the Yota (and Honda) VVT mechanism. It's how they vary the lift (by shifting the pivot point of the rocker)
Clever stuff.
Of course, the rover system is completely different and doesn't actually modify the lift, just the timing....
