Help, metal to metal noise coming from front left wheel!?!
Scottd
Post by Scottd » Sun Apr 23, 2006 1:20 am
I only hear it going over bumps once the car is warmed up a little. It is getting worse too.
Any ideas what to check (and how to do it!?).
It could be unrelated.... but, I did just fit new suspension and I had to undo a bolt on the 'anti roll bar drop link' a little to get the bottom suspension bolt off and on. I screwed it back in again close to where I thought it was. These bolts are very close but there's no marks on them from hitting off each other when driving so it seems to be ok.
After fitting new suspension I'm going to get the geo done soon, but I'd like to sort this problem before getting it done in case replacing what ever is wrong screws up the geo again.
cheers
Scott
Lawrence
Post by Lawrence » Sun Apr 23, 2006 9:49 am
please descibe the noise
duration and frequency etc
Post by mac » Sun Apr 23, 2006 11:09 am
Scott,
Can't help with the description given but just a pointer for 10.
If you prevent the nut (right hand arrow) from turning by using an open ended 17mm spanner then you don't need to remove the drop links.
HTH
Scottd
Post by Scottd » Sun Apr 23, 2006 1:13 pm
Lawrence wrote:please descibe the noise
Just like metal hitting metal each time I go over a bump. The bigger the bump the louder the noise. It doesn't go away when I touch the brakes so isn't brake pad rattle. :?
mac wrote:Scott,
HTH
Yea I didn't remove it completely, I just had to screw it back a little like you says.
cheers
Scott
Scottd
Post by Scottd » Sun Apr 23, 2006 4:01 pm
Here's a pic of those bolts I was talking about which seem a bit close to me?? Don't think they are the cause of the noise tho :?
scott
Post by Rich H » Sun Apr 23, 2006 4:23 pm
Is that how they are now or during the suspention swop? That drop link dosn't look vrey tight! :shock:
Scottd
Post by Scottd » Sun Apr 23, 2006 4:39 pm
RICHARDHUMBLE wrote:Is that how they are now or during the suspention swop? That drop link dosn't look vrey tight! :shock:
Oh bugger, ur probably right :oops: That's how it is now, probably slack and probably causing a suspicious metal to metal sound lol.
Thing is if I tighten it up more the bolt touches the bottom suspension bolt. Maybe time to saw a bit off the suspension bolt??
scott
Post by Rich H » Sun Apr 23, 2006 4:51 pm
If you can turn the bolt around as the bolt head will be smaller. Hopefully that will stop it!
HTH
Rich :thumbsup
Lawrence
Post by Lawrence » Sun Apr 23, 2006 4:59 pm
:D
Scottd
Post by Scottd » Sun Apr 23, 2006 5:26 pm
lol I'm sure there was I reason I didn't do that :scratch
I'll get me coat :) :leave
Post by Rich H » Sun Apr 23, 2006 5:28 pm
Even better, get your spanners and jack then get outside! <BG>
Scottd
Post by Scottd » Sun Apr 23, 2006 6:30 pm
Sorted, was a bit of a nightmare gettin the bolt head past the tie bar bolt but that's it fixed, noise gone, cheers all :D
scott
Post by Rich H » Sun Apr 23, 2006 6:33 pm
Another successful case!
:wink:
