Hmm, shiney bits... (Throttle lever content)
Post by Rich H » Sat Apr 22, 2006 9:51 am
Finally remembered to order a throttle likeage wile ordering things I needed from Geary:
Seenig at the rally cross Nova has died for the moment, I'll not be going to ingleston :roll: so this will be todays task, as well as sorting out that bloody handbrake cable rattle!
Post by mac » Sat Apr 22, 2006 9:52 am
Snap!
Just heading out to pick mine up from the post office, and will also be fitting it today.
Post by Rich H » Sat Apr 22, 2006 2:27 pm
Didn't take long and throttle response is sharp as it should always have been.... :roll:
Still not sure about the rubber grommety thing on the end of the thottle cable, seems designed to introduce wobble....
Another job done :thumbsup
The handbrake cable seems to have cured itself too :D
Post by mac » Sat Apr 22, 2006 6:39 pm
Decided to do DDtB's ball joints instead.
Glad to hear it's not a biggy
Post by Rich H » Sat Apr 22, 2006 7:05 pm
Do you have double jointed shoulders? That was the only real problem :lol:
The two big phillips head screws are made of cheese (Shock horror :roll:) and f-ing tight and I didn't disconnect the cable as the plastic clip looked tricky to remove in one piece. Only took about 1/2 hour.
Do you want to do my ball joints too? :lol:
I take it you have a ball joint removal tool, how long does it take to do a corner?
Post by mac » Sun Apr 23, 2006 4:51 am
Depends - I probably do it the long way by removing the hub carrier.
Shouldn't take more than 1hr per corner, even doing it the way I do. Does help if the ball joint hasn't been welded in and snaps the head of the press bolt!
I bought a ball joint press from geary - stephen got one from ebay, much of a muchness to be honest - one is better in one respect the other in an other
Post by Rich H » Sun Apr 23, 2006 10:23 am
Nice one. That will prbably be my next project. Pretty sure that mine are the original 1997 vintage jobbies :roll:
Next question is weather to go for the bushes too.....
Post by simon » Sun Apr 23, 2006 10:55 am
Nice mousemat :lol:
Post by Rich H » Sun Apr 23, 2006 10:59 am
Free mousemat!
:wink:
Post by mac » Sun Apr 23, 2006 11:05 am
Rich,
As far I know the bushes are a complete barsteward to do.
I would only change them if you've got play in them. We noticed some play in DDtB's yesterday when I was checking for play in the top ball joint.
That will be an interesting job when it needs done. I know that Brunty has tackled it in the past.
Post by Rich H » Sun Apr 23, 2006 12:25 pm
I'll check them for play when I do the ball joints.
Cheers Gents :thumbsup
Post by Shug » Mon Apr 24, 2006 11:56 am
Heh, the next batch were delivered to Eliseparts then....
Mine arrived on Thursday :)
Post by mac » Mon Apr 24, 2006 12:00 pm
I just need to find a scrawny, lanky person to fit it for me.
Think if I went head first into the footwell I
A) wouldn't get past the steering wheel
B) would probably have to be cut out.
Post by Shug » Mon Apr 24, 2006 12:12 pm
Fcuk off :finger
Nah, seriously, if you want it done, I'll give you a call and I'll do it after I've done mine (and found any pitfalls)
Post by mckeann » Mon Apr 24, 2006 12:22 pm
if i can fit, so can you mac. just need to get pulled out by your feet
