Quick question for the engine builders....
- steve_weegie
Gents,
Is the liner to block sealant i need just blue hylomar? Part number i have is GGC 102 but needless to say my local rover dealer has never heard of it!
Steve
Steve
Re: Quick question for the engine builders....
I have some blue Hylomar in the garage , aero grade . Its been in there for years , dont think it goes off .
Don't know how much you will need , its about half a tubes worth .
No lotus
Exige Sport 350 (Sold)
Evora S (sold)
Evora S (sold)
It goes all gloopy and refuses to spread quite quickly, get some fresh
wrong thread...Rich H wrote:At least it won't catch fire on the Liz...
Make it out of Phynol board / Paxolin, much tougher than plywood
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
S1 Elise Honda K20
VW T6.1 family bus
Bugger, too slow...
Yes it does seem as though GGC 102 is hylomar blue - don't use that for the sump, cam or bearing ladders though!!!
Did I give you a tube of Dow Coring 736 (red silicone RTV) for the sump? If not, got some here.
Why? That's what I used IIRC....robin wrote:Yes it does seem as though GGC 102 is hylomar blue - don't use that for the sump, cam or bearing ladders though!!!
The liners are floating so need the non drying hylomar for movment but will get displaced from fixed fits and clog internals, at least thats what i think, rest assured Robin will be allong shortly. Either way Im sure you shouldnt use for cam, sump or bearing ladders, think someone did it on a rebuild blog once and had to remove clean and refit?
Hairdresser at heart.
- steve_weegie
Cheers guys.
I'll acquire some blue hylomar goo for the liners and will use my red goo for the cam and bearing ladders (loctite anaerobic stuff)
And woody, yes you did indeed give me some other red goo for the sump with the molykote for the crank
Anyone know where i can get hylomar from? Machargs were a bit clueless when i gave them the part number...
Hellfrauds
