plug cover
hiscot
plug cover
Post by hiscot » Fri Aug 29, 2008 4:26 pm
i now have two options to stop water filling the plug holes
1 fit the later euro 3 cam cover coil packs and plastic housing ( i have after market ecu )
2 find some way to seal the gap from an after market alloy cover to the cam cover ( i dont want to use goo of any sort )
option one does any one have the required parts for sale ?
option two any engineers in here that can get there head around a solution for a decent seal i recon there may be a market for such a thing
maybe machining the alloy plate to take a wiper blade insert along its edge ? or a lower firm gasket seal of sorts that sits below the alloy plate ?
bob
Re: plug cover
Post by mac » Fri Aug 29, 2008 4:36 pm
Just use the EU3 plastic cover over the top of the EU2 cam casing.
Might need that one of the bolts on the plastic cover can't be done up - but since I've been running for yonks with only one bolt in it I don't see the problem.
hiscot
Re: plug cover
Post by hiscot » Fri Aug 29, 2008 4:49 pm
ahh i see mac does it clear the plug leads from a dizzy and just sit on top
i would like to keep the alloy plate if poss but its a poor fit i can see i would have problems with it
bob
Re: plug cover
Post by mac » Fri Aug 29, 2008 5:02 pm
It should clear them without an issue - you don't really need the alloy plate on and if you did keep it on it would make the plastic cover sit too high - Problem is that you can't dremell it to the right height as you would loose the built in washer bit (best way for me to describe it) which means that you would have no way of tightening it down.
the only place that you will have an issue is at the dizzy cap - if you look at the EU3 plastic cover it sits over a bit like a hat so that would need a bit of scuplting work.
