nose badge off
nose badge off
Post by Scotty C » Wed Aug 13, 2008 4:59 pm
Has anyone removed the nose badge off there car.
Are the new ones just stuck on?
I have done this before but it was the old type that screwed in from the back.
Re: nose badge off
Post by mckeann » Wed Aug 13, 2008 5:03 pm
new ones are stuck on, well, thats what i read rather than what i actually know. Go on, just go at it with a screwdriver :lol:
Jacobite
Re: nose badge off
Post by Jacobite » Wed Aug 13, 2008 5:46 pm
Yea the new one's are stuck on as Mckeann said
Protect the surrounding paintwork then warm it with a hairdryer and use fishing gut or a cheese wire to so cut through the sikaflex that holds it on, then tar remover(so I've read) to clean off any remaining adhesive
ninja
Re: nose badge off
Post by ninja » Wed Aug 13, 2008 10:31 pm
mine was just stuck on
ninja :drive
Re: nose badge off
Post by ExigeKen » Wed Aug 13, 2008 11:53 pm
About a year ago Dezzy posted up how he took his badges off and replaced them
Edin430
Re: nose badge off
Post by Edin430 » Thu Aug 14, 2008 12:20 am
Easy job - hairdryer and fishing wire needed.... Heat it up, gradually slide fishing wire under it pulling both sides back tight.
Done :thumbsup
Re: nose badge off
Post by Scotty C » Fri Aug 15, 2008 11:45 am
X7LDA wrote:Easy job - hairdryer and fishing wire needed.... Heat it up, gradually slide fishing wire under it pulling both sides back tight.
Done :thumbsup
I used hairdryer and a very small screwdriver.
cheers
Scotty
Re: nose badge off
Post by Sanjøy » Fri Aug 15, 2008 1:34 pm
Soooooo what is on there now ?!
Re: nose badge off
Post by Scotty C » Sun Aug 17, 2008 6:12 am
Proton badge, that will make people think :damnfunny
No I changed it for a black one.
