Funny Noise (not funny haha)
pete
Vexatious Litigant
Post by pete » Tue Aug 12, 2008 12:43 am
There is a funny noise, like something is loose coming from my rear driver's side wheel.
It doesn't happen all the time but every journey and loud enough to be audible outside of the car (heard Suzy coming up the street the other day) and seems worse when warm. It sounds like something metal is jangling, for want of a better expression, like a loose nut in a metal bowl being moved around. Almost seems in time with the wheel going round.
The same wheel seems to clunk going over big bumps in a way the others don't.
At this point I would like to nominate myself for the annual "Worst description of a noise leading to possibly the most pointless post in a serious category" award....
Errm vague as all that sounds, any ideas?
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
Edin430
Re: Funny Noise (not funny haha)
Post by Edin430 » Tue Aug 12, 2008 1:12 am
Yup sounds like you have a problem with that wheel... :lol:
If its a "clunk" noise then I could bet its the pad and caliper moving about. It'll make a slight squeeling noise from the outside and inside it will sound like a rattle/clunk everytime you hit a bump on the road.
Easy fix with some anti-rattle pads from Eliseparts :thumbsup
Actually easy was to find out - Go out to the car - put both hands on the caliper and see if you can "jiggle" it about... If it moves at all - thers your problem :D
Post by BiggestNizzy » Tue Aug 12, 2008 8:13 am
Sounds like a reason to pop over and suck air through my teeth :D
Post by Rich H » Tue Aug 12, 2008 8:49 am
Mine does that, not found it in 2 years...
antonywelsh
Post by antonywelsh » Tue Aug 12, 2008 8:50 am
X7LDA wrote:Yup sounds like you have a problem with that wheel... :lol:
i've nothing useful to contribute... just felt like laughing.
hope you find out whats wrong - i had a 'funny' noise coming from one of the mazda's rear wheels... but it 'kinda just went away' :|
1999 Bronze MX-5 stuck with for the foreseeable future spec :(
2006 3-dr Megane boot space spec
Post by Shug » Tue Aug 12, 2008 9:01 am
Very possibly wheel bearing at low speed. Does it growl as you pick up pace?
Post by Rich H » Tue Aug 12, 2008 12:02 pm
Mine is a sort of jingly noise, like a minature morris dance going on, mostly its on rough roads.
Sounds like a loose washer, but I can't find it!
Matelotman
Post by Matelotman » Tue Aug 12, 2008 12:26 pm
I asked Ali to investigate my "jangling" when my car was getting serviced. Result was....... TADTS.
Peter
Post by Peter » Tue Aug 12, 2008 1:21 pm
One of the heat shields? Sounds like a vibrating metal plate but is usually particularly bad a specific engine rpm?
Can normally be replicated when the car is stationary, if not then may well be a drive train issue.
Post by robin » Tue Aug 12, 2008 7:46 pm
If it's an S2 it could be the secondary O2 sensor unwinding itself from the exhaust.
Also the two little metal wings that help support the clam/undertray in the lower rear wheel arches.
Pads tend to go clack-clack-clack whilst driving but will stop with application of the brake pedal, so if you can reproduce while rolling, press the brake pedal and see if it "goes away" - if it does then you know it the brakes.
The suspension can go clonk-clonk either damper noises or bushes.
The little solenoid in the charcoal cannister is often blamed as a weird source of clicking, and it would only come into play once the engine was warm.
pete
Vexatious Litigant
Post by pete » Thu Aug 14, 2008 7:07 pm
Nizzy diagnosed it by such controversial measures as "looking under the car" and "taking the wheel off".
Apparently the shocker shouldn't have oil pissing out the bottom.
I still say that using The Force (ie hearing a new noise and wondering really hard what it might be)is just as valid method of vehicle diagnostics but there you go :D :D :D :D
'11 - '17 S2 135R
'23 - ?? Evora
