Flexi has gone - upgade Opertunity
Post by BiggestNizzy » Mon Jul 07, 2008 4:26 pm
My flexi pipe has gone and my options seem to be
  • repair with a flexi section from partco - cheap and chearfull
  • Stainless steel flexi section - not cheap and your left with a standard exhaust just in a different material
  • Replace with a full stainless steel 4-2-1 manifold - expensive and I hopefully I will get a summer bonus that will pay for it :D
I am leaning towards the later ;)
The elisparts one looks right but doesn't have a flexi section,
the one on the janspeed website looks as if it's just not long enough to reach all the way back to the cat :?
Had a nosey on the elise-shop site and the larini looks nice and shiny
anyone know of any more ? and the pro's and con's of each ?
also as it's fecked I would be needing one sooner rather than the 4 year wait some have experienced
steve_weegie
Re: Flexi has gone - upgade Opertunity
Post by steve_weegie » Mon Jul 07, 2008 5:04 pm
Eliseparts should sell the piper manifold with flexi, and i believe it is a pretty good upgrade, without going to a full solid system and the associated engine mounts....
Its on my shopping list :twisted:
fd
Post by fd » Mon Jul 07, 2008 8:11 pm
I have a Janspeed 4-2-1 with flexi . . . the flexi is seperate and replacable, done a fair few miles with it and no probs . . . I have the small bore one which is better for lower powered engines, mines is only 170ish . . .
Fd
Post by meatball » Mon Jul 07, 2008 8:52 pm
Jinty....are you watching this thread??
Post by Rich H » Mon Jul 07, 2008 9:56 pm
Janspeed small bore here. As FD says the flexi is replacable its a bit on the short side though.
Post by woody » Mon Jul 07, 2008 10:31 pm
Rich H wrote:Janspeed small bore here. As FD says the flexi is replacable its a bit on the short side though.
Still over £100 though - in true pikey fashion I had just the flexi chopped out and a new one welded in for £35 :D
Nizzy :thumbsup Thought it was after getting back in my car.
Post by BiggestNizzy » Mon Jul 07, 2008 10:36 pm
Did the pikey thing on my clio as the flexi is attached to the Cat on the clio
http://www.eliseparts.com/shop/index.ph ... cts_id=408
This is what I have my eye on, I am guessing it's the small bore version I don't have anything near 170bhp so anything big bore would probably be a step in the wrong direction.
anyone fitted one before as it looks a real PITA ?
Post by BiggestNizzy » Tue Jul 08, 2008 5:30 pm
Going to order one tonight :D
Kev
Post by Kev » Tue Jul 08, 2008 5:35 pm
I've got a piper 4-2-1 fitted, but I got it fitted as part of my engine upgrade package from Dan (former JPS) so couldn't tell you what it's like to fit. But it is the nuts 8)
S2 Elise ST (V6 spec)
Audi A4 Tdi (Shed Spec)
Discovery 3 (Wifes Spec)
steve_weegie
Post by steve_weegie » Tue Jul 08, 2008 5:54 pm
BiggestNizzy wrote: anyone fitted one before as it looks a real PITA ?
Never fitted one directly, but have had the manifold off... You may find that the manifold studs unscrew, rather than the nuts, so i'd advise getting a new set of studs to be on the safe side. If the studs come out of the head ok, or the nuts just unscrew ok, it will just be a slog... albeit a dirty one! May need to loosen the driver side engine mount to get the new manifold in, but again this isnt tragic...
Basically, if you need to unscrew anything, make sure you've got new bits to replace them... just in case :lol:
HTH
Steve
Post by BiggestNizzy » Tue Jul 08, 2008 6:18 pm
Does anyone have a set of ramps I could borrow ?
Post by BiggestNizzy » Wed Jul 09, 2008 5:58 pm
Is it worth using exhaust heat wrap ? while I have it all off
steve_weegie
Post by steve_weegie » Wed Jul 09, 2008 7:52 pm
I believe that using heat wrap to keep the heat IN the manifold downpipes will increase gas speed and MIGHT give a few extra ponies, but unless you're planning a mega HP engine, I doubt its worth it....
Post by Shug » Thu Jul 10, 2008 9:21 am
Rich did it and I'm sure he'll mention how the engine bay flooded out smoke like it was on fire, while it bedded in. That said, anything that keeps the temp down by the bulkhead/alternator can only be a good thing. Gordon Wright's totally standard engine produced 140odd bhp with the inlet manfold de-flashed & the zorst de-flashed and heat-wrapped.
I'd agree though, for performance, not worth the hassle, but it'll keep your alt alive longer so I'd go ahead and do it.
fd
Post by fd » Thu Jul 10, 2008 9:45 am
Aye, the important bit, however, is that removing the flexi section is a 15 minute job and not the nightmare job of removing the whole manifold ;-) . . .
Fd
