trous kits
davidwilson11
trous kits
Post by davidwilson11 » Wed Jun 25, 2008 11:34 am
Has anyone fitted nitrous to their s2 exige?
if so could you let me know some info on the kits and how much power i should put throught them.
Look forward to the responses.
tenkfeet
Re: trous kits
Post by tenkfeet » Wed Jun 25, 2008 11:54 am
Get a supercharger . :?
No lotus
Exige Sport 350 (Sold)
Evora S (sold)
davidwilson11
Re: trous kits
Post by davidwilson11 » Wed Jun 25, 2008 12:02 pm
well thats an option, is there a bolt on standard lotus kit.
steve_weegie
Re: trous kits
Post by steve_weegie » Wed Jun 25, 2008 12:32 pm
Go on.... You know it makes sense :wink:
lotustype116
Re: trous kits
Post by lotustype116 » Wed Jun 25, 2008 12:38 pm
Dastek do a progressive N2O kit that runs of the back of their Unichip piggyback Ecu. The salesman had me hooked till i discovered its not compatible with the Z22SE Ecu :cry:
The downside is it costs the best part of 2K :shock: And requires splicing into the main loom :(
Craig,
VX220 Lightning Yellow
Vectra VXR Estate
whaleys
Re: trous kits
Post by whaleys » Wed Jun 25, 2008 3:29 pm
You been watching too much Fast and the Furious? :lol:
davidwilson11
Re: trous kits
Post by davidwilson11 » Wed Jun 25, 2008 3:59 pm
ha ha no not been watching too fast to fustrated, just looking to spend a little and gain some horses.
cant be bothered going down the engine swap or turbo route.
Re: trous kits
Post by tut » Wed Jun 25, 2008 6:13 pm
Outside of the boy racer community and pub talk, I can not see an application for NOS in an Elise, other than the way that Steve Guglielmi uses it in his Time Attack car.
He is in the Pro Class against 900hp Evo's and Scooby's, so needs it on the straights to be competetive and give him 520+hp. But he is only running 3 or four laps at a time. I could add it to my car for another 80hp up the straights, but what is the point for trackdays?
If you were speccing a car for 1/4 mile competition it would be different, but I doubt if you have that in mind.
Re: trous kits
Post by woody » Wed Jun 25, 2008 6:24 pm
thinfourth
Re: trous kits
Post by thinfourth » Wed Jun 25, 2008 8:14 pm
Fine for a straight line but i would not want to use it if there is corners involved
Oh and the cost of refilling a bottle is pretty much ouch
steve_weegie wrote:ImageImageImage
Oh thats not very true
yes you can get large power increases but it can very very easily damage your engine through over stressing it or getting the mix wrong and it munches a piston. And as to using it on a diesel unless you seriously play with the fuel pump its useless, its far better to use propane injection
