Tyre Sizes
Edin430
Tyre Sizes
Post by Edin430 » Sat Jun 21, 2008 3:35 pm
I know the standard tyre for the front of an Exige is 195/50/16 but would it matter much if I put on 195/45/16's on?
Also, what are the digits after? The tyres I am looking at (to match the rears) have 84w after them... :?:
Thanks
Re: Tyre Sizes
Post by meatball » Sat Jun 21, 2008 3:47 pm
It'll be a lower profile tyre.....the digits after are the speed rating of the tyre.
Edin430
Re: Tyre Sizes
Post by Edin430 » Sat Jun 21, 2008 3:56 pm
Lower profile won't matter much I guess when its only 45 not 50...
Does the speed rating matter then? 84w ok for normal road driving?
EDIT - Just checked and I know the W is okay now.. And the 84 is in line with the load of the vehicle. So guessing it should be okay :thumbsup
philthy
Re: Tyre Sizes
Post by philthy » Sat Jun 21, 2008 5:30 pm
It wont be the same - I had some 45 profile tyres on the exige instead of the 50s and it scraped a lot more at the front over speedbumps etc than on the 50s. It also understeered more.
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
Re: Tyre Sizes
Post by BiggestNizzy » Sat Jun 21, 2008 5:33 pm
the 45/50 is a percentage of the width of the tyre so going from 50 to 45 will drop the car close to 10mm
http://www.carbibles.com/tyre_bible.html#aspectratio
Edin430
Re: Tyre Sizes
Post by Edin430 » Sun Jun 22, 2008 10:55 am
hmmmmmmm that changes it slightly.... 10mm is quite a lot considering how low the car already is!
Back to the drawing board :blackeye
Re: Tyre Sizes
Post by Victor Meldrew » Sun Jun 22, 2008 11:17 am
Does your Exige have ABS.....?
If so it will ca confuse the wheel speed sensors and may trigger the ABS at the wrong time or not at all....
Had a similar problem with a peugot a while back, the abs released the brakes every time I slowed below 5mph down for a junction.....
Edin430
Re: Tyre Sizes
Post by Edin430 » Sun Jun 22, 2008 7:57 pm
Victor Meldrew wrote:Does your Exige have ABS.....?
Yup it does indeed !
Investigating different tyres at the moment. May just buy a full set of T1-Rs as originally planned to avoid any hassle :roll:
