Another worrying noise ...Problem solved with pics.
Jamie84
Post by Jamie84 » Thu May 22, 2008 10:09 pm
Driving along today and noticed a clicking noise comming from front left , in sync with the speed of car.
Automatic guess was nail in tyre , sounded exactly like it .
I'v had a good feel around he tyre and cant feel anything :?
Gonna get the wheel off tomorow and hopefully it is just a nail that can be repaired.
Kinda glad the noise is comming from the front though Id be alot more worried if it was from the engine , Is there any know more serious problems that could cause such a sound ?
Cheers guys .
Re: Another worrying noise ...please read.
Post by tut » Thu May 22, 2008 10:22 pm
Did it make a difference when you gently touched the brake pedal?
Post by woody » Thu May 22, 2008 10:27 pm
Sounds like the brake pad clips might be in the wrong way round. very easy to do, and just as easy to sort.
Jamie84
Post by Jamie84 » Thu May 22, 2008 10:33 pm
NOOPS 160 wrote:Shocker noise maybe :?:
dont think so , not sure what shocker noise would sound like but Id imagine it would be more dull sounding and klunky ?
This is a definite high pitched clicking noise
Jamie84
Post by Jamie84 » Thu May 22, 2008 10:35 pm
I'll check tomorow if it goes away when braking ...
Brake pads were changed few months back by Ali , could the clips being wrong way round be somthing that would only be noticed after pad wear?
Post by kenny » Fri May 23, 2008 8:19 am
If they are Pagids its probably just them rattling around, mine do exactly the same, usually after a month or two driving. After that they tend to settle down again.
Post by meatball » Fri May 23, 2008 1:02 pm
kenny wrote:If they are Pagids its probably just them rattling around, mine do exactly the same, usually after a month or two driving. After that they tend to settle down again.
Once again I'm with the wee man.....both Jinty and mine do this.....until you get them hot.......brake dust will fill the gap eventually and kill the noise!
Feel free to pop over!
Jamie84
Post by Jamie84 » Fri May 23, 2008 2:52 pm
Defo dont think its normal , It sounds exactly like a large nail in the tyre smacking rather loudly off the tarmac on each turn, had the car out for a long blast last night and it was still there .
I'll get the wheel off either today or tomorow and get a better look but its defo not somthing I would class as normal . Its loud and could easily be heard by someone on the pavement as I pass (not the usuall rumble/knock/rattles Ive learned to live with.
Anyways I'm, off for a dominos will report back with my findings hopefully soon.
s29ttc
Post by s29ttc » Fri May 23, 2008 3:28 pm
SOunds to me like a CV joint if it where FWD. When they are worn they make a clicking noise to the speed of the car but I dont even know if they use them on exige?
1999 S1 Elise 111S - Fun Spec
Jamie84
Post by Jamie84 » Fri May 23, 2008 3:30 pm
when i say clicking its like .......someone throwing a small stone off the road with force , Must of the suggestions i woud think would be more of a clunk ?
Anyways I'll see e morraz
Post by Andy G » Fri May 23, 2008 3:41 pm
call Ali and ask for his opinion mate :thumbsup
It wont be the brake clips though - might be worth standing on the brakes to see if that lessens or worsens the noise?
Post by mac » Fri May 23, 2008 4:00 pm
Jamie84 wrote:when i say clicking its like .......someone throwing a small stone off the road with force , Must of the suggestions i woud think would be more of a clunk ?
I know what it is.........................
......... it's the orange glow sticks you attached to the wheels :mrgreen:
VXJON
An Equal Opportunities Lover
Post by VXJON » Fri May 23, 2008 4:08 pm
:whip :lol:
Jamie84
Post by Jamie84 » Fri May 23, 2008 4:47 pm
howl shut it creaky bones. :mrgreen:
Jamie84
Post by Jamie84 » Sat May 24, 2008 4:17 pm
SO......I took my wheel off this morning to discover that the small copex carrying 2 cables , I presume for the ABS , Had came loose and must have been smacking of the alloy when turning.......phew.
I did think to be honest that the intervals between each "click" were too often to be somthing on the tyre hitting the tarmac on each turn . The cable had clearly been hitting each spoke on the alloy.
Anyway , When driving this morning my ABS light came on and initially I though I had more problems in store but after removing the wheel you can clearly see that the alloy had cut right through one of the cables in the copex which must have cause the light to come on.
So 2 crimps and some black insulating tape later , problem solved.
Quite satisfying sorting the odd wee problem yourself , Wonder how much Id have been stung for in a local garage for somthing so simple !
Sorry for the big picture , cant seem to rezize it if you scroll over to the right you can see the cable. .
