The sound of music...
Sassy
Post by Sassy » Fri Mar 10, 2006 11:31 am
Right, I've already been told it's better to listen to the music of the engine, but there's still the odd time a girl wants to crank up a bit of Barbie Girl* at the traffic lights...
So, has anyone done anything to the stereo/speakers? And how to upgrade it with minimal disruption? I don't want to bolt anything to anything, or have too many extra boxes or wires hanging about, but:
1. Do I need an interface box to get the ipod working with the Blau Woodstock? A friend has an Alpine, but needed a fairly large interface to get the pod working with it. Is it possible just to have a wire without a clumsy box half way along it?
2. The MMC card - apparently this is the same as the thing in my phone. So is this a better idea than trying to connect up an ipod? Just put a whole load of songs on the MMC and slot it in the stereo?
3. Speakers - I don't want everything pulled out and messed about with as inevitably things don't slot back in as neatly as the factory install, but I would like slightly more capable speakers. Are there any reasonably priced, but better ones that fit straight into the existing holes?
*joke. Honest.
Post by jj » Fri Mar 10, 2006 11:36 am
1) I ordered one of these on Wednesday (and it arrived this morning) http://www.bluespot.co.uk/stock/auxin2.asp
7 quid and job done. They also do a version that has the box and allows for control via the H.U. but its 70notes.
2)A MMC size card big enough will cost more than the 7 quid for that cable, so I wouldnt bother.
3) As for speakers, a mate of mine fitted Focal components to his S2 and they slot straight in and sound better than the standard ones.
Sassy
Post by Sassy » Fri Mar 10, 2006 11:38 am
So can you (as in I) fit that wire your(my)self? And would it just hang down the back of the stereo?
Post by jj » Fri Mar 10, 2006 11:42 am
Yes,it plugs into the DAB54 and you select AUX1 by pressing the far left button on the HU.. But having done it in my S1 the feeding of the wire through the dash is difficult. I am going to feed mine through the dash so it pops out in the shelf bit, and I can then jam the ipod into the shelf so it sits vertically in its rubbery cover.
Sassy
Post by Sassy » Fri Mar 10, 2006 12:06 pm
Cewl, thanks - I have ordered that lead. Now for the focals...
*slow work day
Post by Andy G » Fri Mar 10, 2006 1:19 pm
I'm getting some 2GB SD cards in shortly from the manufacturer in Korea. I'll post a deal for SE'ers. :D
I've also got the Aux to 3.5mm lead. Best way to do it for next to nothing.
Haven't played around with the speakers yet though.
If you want an ipod interface, have a look at the Dension icelink, which connects through the radio input. Personally though I would't bother.
Post by Sanjøy » Tue Mar 14, 2006 10:10 am
2GB SD Now that sounds interesting..
Also ANdy do you do a Kenwood multistack socket to 3.5 ?
GregS
Post by GregS » Wed Mar 15, 2006 2:48 am
Can the DAB 54 read a 2GB card?
Sure the older DAB53 can only see 256Meg
May be worth making sure of before getting a load of cards.
Greg
Post by Andy G » Wed Mar 15, 2006 10:25 am
Sanjoy wrote:2GB SD Now that sounds interesting..
HI Sanjoy
I've got the blaupunkt unit in mine and use the aux connection to 3.5mm jack. Ideal for all mp3 players :D
Ideal for me, as I usually pinch the one that my shop team have loaded with the most tunes!
Post by Andy G » Wed Mar 15, 2006 10:44 am
GregS wrote:Can the DAB 54 read a 2GB card?
Greg
Gutted, just wrote a monster reply and my system timed out and lost it! :evil:
Still probably would have sent you to sleep anyway. :D
I've checked the manual for the Dab 53 and it can only record (from Dab) on to a 256mb card. The other limitation applies to file playback which is retsricted to 256kbps. Quite why they did that is beyond me. :roll:
As for the card though no stipulations apart from not going over 20 directories or 200 files, which would imply that they haven't set a limit on cards.
I'll take a 1GB card home tonight and try it out if I have time. :P
2GB cards I'm bringing in anyway, and am also trying to get hold of 4Gb cards.
I'll let you know how I fair.
Post by Sanjøy » Wed Mar 15, 2006 2:01 pm
Gitso n fleabay want 30 sovs for a simple multi change socket to 3.5!
Post by ed » Wed Mar 15, 2006 2:05 pm
Ive got the same stereo and i use a cd of mp3s that holds 800mb and a 1gig sd card. I can drive for hours always listening to different music without the faf of lots of cds. :D
Tom
Post by Tom » Wed Mar 15, 2006 2:28 pm
Don't want to tread on anyones toes but I found: http://www.euronetwork.co.uk/ for cables and accessories
to be brilliant. Very reasonably(ie cheap) priced, superfast delivery, and general all round legends.
Personally I'm sick of being screwed around by online parts companies so I like using word of mouth rather than google.
One more tip. Stay away from: http://www.espares.co.uk/ at all costs. They are truly SH*TE!! :chainsaw :flame
Right, rant over.
Post by jj » Thu Mar 16, 2006 12:17 pm
cheers for that link Tom. ordered a bunch of cables for AV that I`d been meaning to go and get stuff at 4pm yesterday and they arrived this morning. Thats service!
Post by ed » Thu Mar 16, 2006 12:44 pm
Just read a thread on exiges.com that 1gb is the max the dab will cope with :( 4 gb wouldhave been ace.....
