Annoying S1 Bootlid !!!
Elisa
Post by Elisa » Mon Mar 10, 2008 10:36 pm
Has anyone had problems with the boot release catch on their s1. Everytime i think the boots shut properly get in drive somewhere and its popped up again :( . Does anyone know if it would b the catch or the boot release cable i have to replace.
Pedro
Re: Annoying S1 Bootlid !!!
Post by Pedro » Mon Mar 10, 2008 10:38 pm
Hey Elisa,
My S1 Engine Bay Hood catch stuck, is that the same as yours, or is yours the front hood..?
Pete
'97 S1 Elise - Ongoing Project Spec
www.dynamic-it.co.uk
craigs135s
Post by craigs135s » Mon Mar 10, 2008 10:40 pm
Speek to Ross he's not long fixed his.
C
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
Elisa
Post by Elisa » Mon Mar 10, 2008 10:43 pm
yup, its the engine bay one, never been the same after i got it sprayed.
Pedro
Post by Pedro » Mon Mar 10, 2008 10:46 pm
Yep,
They appear to be sh*t! on the S1. I never fixed mine, but removed the catch all together. The hood sits down fine, and I just lift with the key hooked under an edge of the lid. Probably not the best solution, but works fine :D
Pete
Post by BiggestNizzy » Mon Mar 10, 2008 11:00 pm
If the cable operates smoothly then it will just need adjusted properly, I had to tweak mine a little after I had removed the lifd and replaced the release with an electric one.
Post by tut » Mon Mar 10, 2008 11:29 pm
Yep, just needs adjusting.
First check that the end of the cable is fully located in the collar where the wire comes through.
Try changing the length of the striker bolt, you can slacken the large collar nut, then screw in or out.
Post by campbell » Tue Mar 11, 2008 1:02 am
Elisa wrote:yup, its the engine bay one, never been the same after i got it sprayed.
Where did you get it painted?
The boot hinge, cable and catch can all be adjusted by some way, most likely just the catch not lining up since the boot was refitted after your paint job perhaps, which points at trying adjusting the hinge first.
Scottd
Post by Scottd » Tue Mar 11, 2008 2:53 am
I've found the rear one fairly easy to adjust, the front one however :shock: Last time the car was at Ali's/SLS I asked him to adjust it - it's prefect now... so I'd recommend sticking it on ur list for Ali. Maybe not much help to you in the mean time tho..
S1 50th Ann.
Post by r055 » Tue Mar 11, 2008 8:54 am
i had the same problem before my cable actually snapped. :roll:
Try adjusting the boot as above - its possible that it just hasnt been put on properly. it only takes it to be a couple of mm out and it wont catch.
As a precaution though, get a piece of string and tie it around the catch then feed it through the hole where the cable goes just now. give enough play on it for it to sit within the liner of the rear wheel arch. That little investment of time will allow you to open up the boot if the cable snaps in the future. :thumbsup Otherwise its drilling the rear clamshell! :?
Pedro
Post by Pedro » Tue Mar 11, 2008 9:35 am
Hi Elisa,
I totally agree with the guys above, if you can adjust & fix you should do that. I removed the striker bolt from the hood as the cable was totally stuck & I couldn't shut the hood at all.
If you're not sure, maybe the guys that done the respray would help..?
Pete
tuscan_thunder
Post by tuscan_thunder » Tue Mar 11, 2008 12:59 pm
r055 wrote:i had the same problem before my cable actually snapped. :roll:
100 per cent agree!
If you can get into the boot now, then get something tied onto the latch - if the cable snaps and the boot is stuck shut it will not be fun.
It's bad enough poking about when you have access to the boot.
You will probably need a new cable. My car has a cable designed for a manual choke as its boot release now - it's ideal as it even comes with the little handle on the end and feeds straight through
Mair throttle, less brake
Scottd
Post by Scottd » Tue Mar 18, 2008 9:08 pm
tuscan_thunder wrote:.....My car has a cable designed for a manual choke as its boot release now - it's ideal as it even comes with the little handle on the end and feeds straight through
Cool, but I am now guessing you've replaced a manual release choke cable with a manual release choke cable?
They had to be from the (rover/ etc) 'parts bin' cause they're fairly cheap from Lotus and that'll be with their 100% mark up!
At least we now know what the Elise boot/bonnet cables were originally made for!? :wink: :thumbsup
S1 50th Ann.
Post by campbell » Wed Mar 19, 2008 1:04 am
Could be useful Scott!
