Anyone know of such a thing ? Found some speakers but they are 15cm and IIRC the S1 is 17cm.
TIA
SP
Speaker adaptors e.g. 16cm -> 17cm
Re: Speaker adaptors e.g. 16cm -> 17cm
That is only 10mm at each mount point. Can you not just file the speaker holes to slots and use washers?
Even better then only 5mm...
SEOT....
SEOT....
I didn't think S1's had speakers due to them weighing too much. Does yours have carpets too??
Exige V6
It was actually a replacement set and it was a set of the Kenwood dual mags which would actually be weight saving over the Alpines, so there
And as for carpets...
