Job For The New Year
111Robin
Post by 111Robin » Sun Dec 30, 2007 7:02 pm
It's 9 months now since I cracked the front clam hitting a deer. It wasn't bad enough to put me off the road therefore I used the car as is throughout the year. I would however like to have it repaired before spring time arrives hence this post :
1. Assuming I can loosen all of the fasteners, I'd be looking for a volunteer around Aberdeenshire to give me a lift off.
2. Concensus on GRP repair appears to be PPS in Inverurie however they don't paint therefore looking for advice on where to go for the finishing. Alternatively if there is anyone else that comes recommended that can do the whole job, please advise.
3. Is there anyone with a trailer or large van that could help me shift it from place to place ?.
Any help provided will be suitably reimbursed of course.
Bernard
Post by Bernard » Sun Dec 30, 2007 11:02 pm
Hi,
I can give you a hand with removing the clam, I stay in Aberdeen but I'm offshore from the 3th till the 9th January
I know somebody with a van.
Bernard
Dax Rush, westfield, BMW X5 SD M, Mini
Post by Mikie711 » Mon Dec 31, 2007 6:15 pm
If you talk to Kieth at PPS and live localish they might pick up your clam for you, did mine. Fantastic job, really good repair and half the front air dam was missing on mine. Can't help with the painting bit, did mine in a rush with Halfords colour match paint!!!, not even close but to be fair metallic is a bugger to spray and match from a tin. If you need a hand give me a shout, home till the 8th.
One place that would give you a top notch paint job is Kinghorn Autobody in Blackburn. You will Pay for it mind but they do all my touch ups on the 911 and boxster before that. First class job, guy to talk to is Kevin Kinghorn.
TBA
111Robin
Post by 111Robin » Tue Jan 01, 2008 6:39 pm
Thank's for the replies guys. It would be handy if PPS could pick the clam up, I'll talk to Keith about this. Once I have everything loosened off I'll post to see who's around to help.
thinfourth
Post by thinfourth » Tue Jan 01, 2008 10:16 pm
If you need big stuff moving give me a shout i could haul a clam no problem
