Bernard
by Bernard » Thu Dec 20, 2007 4:28 pm
Is it a big job to replace the radiator?
Do not know if it is cracked or if it is a hose!!!!
Small leak.....
Dax Rush, westfield, BMW X5 SD M, Mini
craigs135s
by craigs135s » Thu Dec 20, 2007 4:30 pm
If you need to replace it mate its clam off. Am sure someone will be along soon to tell you if it can be fixed.
C
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
- Site Admin
by simon » Thu Dec 20, 2007 5:47 pm
Join the club.
Clam off job to replace, don't replace with another standard one, get one of the full aluminium ones off eliseparts.
It's not too difficult if you want to tackle it yourself, I did mine and tankfeet did his too IIRC.
tenkfeet
by tenkfeet » Thu Dec 20, 2007 6:08 pm
Not too bad to do. It is the plastic end fittings that leak on many as they are sh**te .
As with anything when you have done it once.
No lotus
Exige Sport 350 (Sold)
Evora S (sold)
by Andy G » Thu Dec 20, 2007 7:35 pm
as Si says the upgraded ones are definately worth it.
The normal one will die at some stage, almost guaranteed!
Ali's done about 10 of these since he started SLS alone, let alone god knows how many at MMC before that.
If you need some advice give him a shout.
Bernard
by Bernard » Thu Dec 20, 2007 9:55 pm
cheers for the fast replys ..I had a look on the elise parts website and i will go for the all singing... dancing.... ratiator. I wil start tomorrow stripping the clam.
cross fingers nothing go's wrong..
Bernard .........
Baggy
by Baggy » Thu Dec 20, 2007 10:04 pm
There is a bit in the SELOC wiki page about doing an S2 rad incl taking the clam off.
http://wiki.seloc.org/a/Radiator
Baggy
Silver S1 111s
The Deen
tenkfeet
by tenkfeet » Thu Dec 20, 2007 10:42 pm
Bernard wrote:cheers for the fast replys ..I had a look on the elise parts website and i will go for the all singing... dancing.... ratiator. I wil start tomorrow stripping the clam.
Bernard .........
If you are doing it in a narrow garage remove the bolts and the screws around the door area from the front clam before you put it in . I was stupid and made its very awkward as I had the front wheels off and could not open the doors .
No lotus
Evora S (sold)
Bernard
by Bernard » Sat Dec 22, 2007 6:56 pm
New radiator is installed and the car is al most back together.
Thanks for all the help and info.
Bernard
