Squeeking Steering Wheel
Edin430
Post by Edin430 » Sat Dec 08, 2007 9:29 pm
Very light... Only when turning at low speeds (5mph)
Ideas?
neil
Post by neil » Sat Dec 08, 2007 9:33 pm
turn up the stereo
Post by Victor Meldrew » Sat Dec 08, 2007 9:53 pm
Check the column shroud isnt rubbing... sometimes if you accidently give it a kick when climbing in it can move and rub... just hit it again from the other side.
Scottynic
Post by Scottynic » Tue Dec 11, 2007 7:47 pm
mine does this too, has done since i got the car new!
TOO FAST TO LIVE TOO YOUNG TO DIE!!!
blackbird
Post by blackbird » Tue Dec 11, 2007 7:54 pm
you can take off the steering wheel and check to see that there is grease on the brass ring that the contact for the horn runs on,some cars did not have grease put on at lotus
2F45T4U
Post by 2F45T4U » Tue Dec 11, 2007 10:07 pm
mine did it too. i just sprayed silicone dash polish between the shroud and the wheel.
Post by campbell » Tue Dec 11, 2007 11:41 pm
I think mine has this feature but believe it occurs from nearer, or in, the rack. Not a wear issue as such, just something resonating lightly. Noticed it when changing a gaiter and thought "oh, I've heard that in the car before!"
I just drive faster then you don't notice ;-)
elise82
Post by elise82 » Wed Dec 12, 2007 10:21 am
Mine makes this noise occasionally. Tried moving the plastic surround and goes away but does come back. Just ignore it. :wink:
1998 S1 Elise - Standard
2000 Focus - Dog walking spec
Scottd
Post by Scottd » Tue Dec 18, 2007 2:34 pm
Mine started doing that a couple of years ago, a bit of grease on the joint easily accessible from under the stack unit and it was sorted.
Post by Rich H » Tue Dec 18, 2007 3:02 pm
Lithium grease spray worked for me.
