Pedro
by Pedro » Tue Nov 27, 2007 7:30 pm
Hey Guys,
This will make you laugh...I took the car round to the garage tonight for some petrol, and couldn't get the cap off!!
The car never came with a key, but I have managed to fill it up before, however this time it just spins round like on a ratchet, last time I pushed while turning & it came off...Any ideas please..?
Thanks in advance,
Pete
by BiggestNizzy » Tue Nov 27, 2007 7:54 pm
Drill through the lock
by Dominic » Tue Nov 27, 2007 8:08 pm
BiggestNizzy wrote:Drill through the lock
... watch out for the sparks
Try the ignition key in the lock?
by Rich H » Tue Nov 27, 2007 8:17 pm
Dominic wrote:BiggestNizzy wrote:Drill through the lock
Tha ali cap and brass lock?!?!
by Dominic » Tue Nov 27, 2007 8:23 pm
RICHARDHUMBLE wrote:Dominic wrote:BiggestNizzy wrote:Drill through the lock
I dunno... I don't do technical.... just drive
Pedro
by Pedro » Tue Nov 27, 2007 8:28 pm
It's the factory fitted alloy cap, no key
by BiggestNizzy » Tue Nov 27, 2007 8:29 pm
locksmith ? how much is a new one or one off fleabay ? or try jiggling it with anything it might go I imagine the lock is cheap crap anyway
by Rich H » Tue Nov 27, 2007 8:38 pm
Screwdriver and hammer.
Might not work but you will have fun finding out...
Locksmith will have it apart in no time.
Scottd
by Scottd » Wed Nov 28, 2007 12:56 am
They are expensive £50+ IIRC and I'm not sure if you can even get them from Lotus any more! ?
Again IIRC the locks can go (I realise this isn't you problem) but there is some kind of replacement available. I remember reading about this years ago on the old BBS forum. A search on Seloc should turn up a solution (or even better, BBS, if you're registered you can search their archives all the way back to '96).
by Rich H » Wed Nov 28, 2007 9:04 am
IIRC aren't they off jeep wranglers?
aberdeenelise
by aberdeenelise » Wed Nov 28, 2007 9:51 am
great I've been looking for a site to get me a new one!!!!!!
by BiggestNizzy » Wed Nov 28, 2007 10:13 am
I find that brute force and ignorance usually work, although when it doesn't things tend to get expensive
Pedro
by Pedro » Wed Nov 28, 2007 12:56 pm
Thanks Guys,
I don't think the cap is locked, last time I filled up with gas, it came off ok, I then put it back on turning until the ratchet turned, now when I try to turn the other way to remove, it just spins like on a loose ratchet. I have never locked or unlocked the cap as far as I am aware.
I might try some other keys to see if one can give a turn just to see tho.
Pete
by BiggestNizzy » Wed Nov 28, 2007 1:13 pm
when you turned it untill the ratchet started thats when you locked it.
drive round to a friendly locksmith he should be able to strip it and make a key.
or contact lotus they may be able to get a new key.
or meet lots of lotus owners and try there key
or smash it to bits and get a new one
I will try and pick the lock on mine tonight just to see how easy it is
