by Victor Meldrew » Thu Nov 15, 2007 7:04 pm
Dipped beams stopped working on me tonight...
Side lights come on with the side light switch.
Side lights only come on with the dip beam switch.
With the dip beam switch pressed in the main beams will come on when you flash them and also when you select them by pushing the stalk forward.
But no dipped beam..
I have had a quick look at the circuit drawing and the DIP BEAM RELAY looks like a possible culprit, or possible a fault with the DIP SWITCH not energising the coil on the dip beam relay...?
Any expert advice or prior experiance would be much appreciated
by woody » Thu Nov 15, 2007 8:01 pm
Check the connectors to the back of the lamps? Mine melted and gave some issues.
by Victor Meldrew » Mon Nov 19, 2007 2:04 am
I have done a continuity check and there is a break somewhere from the outlet of the relay to the earthing point. i.e. on the full beam relay base I get a circuit (not quite 0 ohms as it has the bulb elements to go through, but on the dip bean relay base I get no connection.
So either both bulbs have blown on the dip side only (not likely) or the break is after they combine between the bulb holders and the common earth point.
Not knowing where the wiring run is phsicaly, only seen the diagram so far, could this end up being a clam off job to get at the bits or are the two front arches out and or undertray going to be enough for access.?
by mac » Mon Nov 19, 2007 8:45 am
Why not check the bulbs first before ripping out clams etc.
by Victor Meldrew » Mon Nov 19, 2007 9:35 pm
mac wrote:Why not check the bulbs first before ripping out clams etc.
Will do mate, but I dont think both sides would blow at the same time..
Car is now officialy off the road over the winter for some TLC...
- Barefoot Ninja
by tut » Tue Nov 20, 2007 10:25 pm
pussy........
craigs135s
by craigs135s » Wed Nov 21, 2007 12:49 am
tut wrote:pussy........
Where????
C
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
by Victor Meldrew » Wed Nov 21, 2007 2:02 am
i can neither confirm nor deny that statement...
Baggy
by Baggy » Fri Nov 23, 2007 1:11 pm
my money would be on the switch in the stalk being fooked.
Baggy
Silver S1 111s
The Deen
by Victor Meldrew » Fri Nov 23, 2007 10:19 pm
Baggy wrote:my money would be on the switch in the stalk being fooked.
tested that and I have voltage to the coil ok, i.e. I can here it switching. I also have voltage to one side of the relay. I swapped the relays over between the horn and the side lights and the horn worked fine so the relay is ok.
I have a continuity on the circuit on the main beam base to battery earth but on the dip beam base to battery earth there is no continuity. So pretty sure the problem is between the relay base and the earth. Obviously if both bulbs were blown on that filament only that would give the same fault.... but how likely is it for two bulbs to fail like that at the same time..?
Baggy
by Baggy » Sat Nov 24, 2007 12:52 am
From the symtoms you describe above I would try a new stalk... I had similar symtoms ages ago on a rover sd1 & when I took the stalk appart the contacts for the dips were worn away.
I don't know how the vauxhaul ones work inside but on the ones I've seen the dips connections are on a sort of sector slip ring (so they stay on as you indicate) so these are wearing every time you indicate.
Baggy
Silver S1 111s
The Deen
by Victor Meldrew » Sat Dec 08, 2007 9:49 pm
bulbs
